It shows the heat
08.05.2020 16:29 # 1
mustafa142434
hi friends peugeot 206 xdesign 2005 i have a car. Antifreeze flows under the mop of the driver seat of my vehicle. yesterday while on the move with the car, the temperature was between 70-90, while the temperature was between 3-5 seconds, I stopped the vehicle and looked at the water tank. water did not decrease, but did not need to decrease the water since water flows from the heater core. Didn't it have to drain the water because the vehicle was overheating? I wonder if there is a problem in the circulation pump, whether the engine does not take the water from the water tank. Could it be? There is no thermostat in the vehicle, thank you for your help
08.05.2020 16:29 # 2
albayman
If there is antifreeze and water leaking place, it is likely that it has caused air. Sudden increases and decreases in the temperature point indicate this. the leak may need to be removed and vented ...
08.05.2020 16:29 # 3
yavuz25
That the water in the reservoir does not decrease does not mean that the water is not missing. The air has done as my brother said. When the weather is done, the temperature sensor cannot make a full measurement. "Wink"
08.05.2020 16:29 # 4
mustafa142434
Thank you for your answer, but I don't know how to breathe. Can you describe it?
08.05.2020 16:29 # 5
yavuz25
Do not do this unless I find it too difficult. It would be better for a master to do it. Open the cover of the replacement water cap. There are small bleed screws on the pipes. A few of them & nbsp; Then press the starter. Close the screw in the water properly. Do not over tighten the cover of the spare water tank after closing all of them. "Wink"
08.05.2020 16:29 # 6
albayman
If you do not know the location of the screws, if you do not know the bleeding process, I think to get it to a master. Actually it is easy but you need to know its location and logic.
08.05.2020 16:29 # 7
mustafa142434
thank you very much it will be best to have a look at the master
08.05.2020 16:29 # 8
yavuz25
[QUOTE = mustafa142434] thank you very much, it will be best to have a look at the master [/ QUOTE]
is the best. "Wink"
