It searches for radio but does not find any frequency !!
08.05.2020 20:10 # 1
hoca38
Hello to everyone. I bought the 2009 model 1.6 hdi 308 a week ago. Since I bought it, I have been trying for the radio intermittently but I could not get any results. Thanks to the previous employee, he bought a mini "Music Speakers" to plug in the usb and adapted it to the space under the cd player. When I put the cd player into AUX mode, I can listen to mp3 without any problems with usb memory, but when I set the mode to the radio, I cannot listen to the radio via the CD player or the device that I can call this mini tape. Although I have repeatedly searched on each band, I cannot find one radio. When she searches for frequency from the music speakers, it makes assignments like p1, p2. But again there is no sound breath. In short, I could not listen to any radio since I bought it. Is this because the device called Music speakers is installed? Do I need to disassemble this? (The device called " Music Speakers" has usb, aux inputs and it can search frequency?) What should I do?
08.05.2020 20:10 # 2
hoca38
Vehicle comfort model
08.05.2020 20:10 # 3
talip206
Possibly the antenna cable on the back of the tape is unplugged or canceled while processing.
08.05.2020 20:10 # 4
hoca38
Is there an essential reason for Cancellation to use the little apparatus I mentioned? The probability of the antenna cable coming out is a difficult possibility, but it actually works for me. I don't know if I can wear it though. I do not know how to remove the CD player yet. Is it screwed, is it clawed, is it disconnected and is it tampering with the antenna cable? We need someone to describe it.
08.05.2020 20:10 # 5
First of all, welcome to us. We wish you to use your vehicle without accident and good luck. I think the antenna cable has been removed as our friend said, I added a video about tape removal, my teacher will help you.
[TUBE] sm_pzfrkrcc [/ TUBE]
sonerkyl 2017-02-03 09:04:36
08.05.2020 20:10 # 6
pepecura
Although the antenna cable is in place, I should not expect much performance.
08.05.2020 20:10 # 7
ggitaristt
Normally it draws radio well.
Most likely your antenna connection is problematic (I think the antenna socket is out, less likely, but the cable may be broken or the antenna may be oxidised), and a small possibility is that you have broken the radio settings (somebody who understands a bit).
