It's an electrical problem, but what is it? (Video)
08.05.2020 17:23 # 1
peugeot22
Hello friends,
When there was no problem in the car, I opened the door in the morning to go to work in the morning after I opened the door, and as seen in the video, it started to cause a problem like the electric icon on the information display and dashboard. At the same time, the situation in the ceiling light is the same, it is blinking. And under the steering wheel, the sound you hear from the fuse part clicks, the sound is not normally like in the video, it is not like the sound of a hammer, it is like the sound coming out of the fuse box when we lock the doors. no. But when I took the key out of the socket, I came across the same sroun, I removed the battery head now, I'm waiting for your help and advice, the vehicle is 2004 model 206 cc 1.6
[TUBE] LErIaXpeRSk [/ TUBE]
08.05.2020 17:23 # 2
samet2461
I think it must be a role that sets the time when the car goes to sleep. it goes into sleep after a certain time, it turns off when the ignition is turned on, it may be broken. because it makes the same sound when turning off the ignition and going to sleep mode after 1 minute. my opinion is like that. the part that causes the vehicle to enter and exit the sleep mode is either broken or there is a short circuit, and the electricity is coming and going. samet2461 2013-02-22 18:14:00
08.05.2020 17:23 # 3
muratoner
My friend may be on battery. muratoner 2013-02-23 00:21:14
08.05.2020 17:23 # 4
peugeot22
Thanks guys for your opinions, let's see an electrician today.
If the problem is solved and whatever the reason, I will write it here.
08.05.2020 17:23 # 5
bjkamil
as if a virus has entered the vehicle's brain :) I agree with samet2461. there seems to be a problem in sleep mode.
08.05.2020 17:23 # 6
peugeot22
The problem has been solved, friends.
We made foil on the ceiling to look like a glass ceiling. When I got up in the morning, I saw a drop of water from the ceiling lamp, and when I turned off the lamp, the problem disappeared. There was water contact with the electric cables there. thanks "Wink"
