It is normal if the vehicle is more agile in half a gas
08.05.2020 18:20 # 1
gkhn08
Hello guys,
I have noticed that it was a matter in my mind for a while, I have noticed that the vehicle is on the ramp or straight road, not full throttle pressure, but half throttle or a little more than half pressure, and is it serial?
vehicle 2004 partner 1.9
I would like to thank everyone who commented to my brothers who did not comment.
08.05.2020 18:20 # 2
adatuna
It is normal that it does not eat gas ... it is normal ... the vehicle takes over gradually.
08.05.2020 18:20 # 3
gkhn08
[QUOTE = adatuna] is the situation of not eating gas .. it is normal ... the vehicle of course takes over gradually .. [/ QUOTE]
It is not a transfer event, that when the vehicle is in a normal course, the acceleration of the vehicle should increase from the pressure you press on the flat road, but it does not get rid of the full acceleration pressure, but as I said, the vehicle accelerates and agitates faster when it gives half the pressure to the pedal.
gkhn08 2014-02-25 21:20:09
08.05.2020 18:20 # 4
adatuna
this happens in all vehicles .. I think it's a normal situation ...
08.05.2020 18:20 # 5
Turgay_66
Depending on the gear of the vehicle, I think it is reversed immediately in low gears but it is normal because it cannot be flipped at 4 or 5 gears.
08.05.2020 18:20 # 6
gkhn08
Guys, I think I couldn't explain the problem.
Let's say that we are driving on a straight road, the vehicle is driving full throttle in 5th gear, and it does not go so, but when you slowly move your foot from full throttle to half throttle, it gets faster and goes faster than full throttle normally, shouldn't it be the opposite?
08.05.2020 18:20 # 7
adatuna
If full throttle runs in 5th gear for a long time, it normally slows down when you pull your foot slightly ... If the vehicle accelerates even more when the full gear is gone in 5th gear for a long time, there is a problem.
08.05.2020 18:20 # 8
ahmed206
This issue is actually my head. As the friend said, it feels like it gets faster when he takes root and then pulls his foot a bit from the gas, maybe psychologically, maybe I couldn't estimate the amount of gas that the vehicle wanted now but I have a thought. You will step on the gas according to the current cycle of the vehicle. I throw it, if it is 2000 times, press it little, if it is 4000 times, it is very bass I think this is the ideal for speeding up. This pushes me to the thought, okay, there is a sensitive accelerator pedal under our feet, but we can get whatever the power of our vehicle is.
That's why I think it would be best to buy a car that will provide the ideal torque-bg and sit back.
08.05.2020 18:20 # 9
gkhn08
[QUOTE = ADAT to] 5. If full throttle goes in gear for a long time, it normally slows down when you pull your foot slightly ... but if you put it in 5th gear, you will take root directly without gradually increasing the degree of throttle. If the vehicle accelerates even more when the throttle is gone after full throttle in 5th gear for a long time, there is a problem ... [/ QUOTE]
As you wrote in the last line, the car is in the normal 5v speed range, the gas is completely full, and the car is running smoothly at full throttle.
08.05.2020 18:20 # 10
gkhn08
[QUOTE = bitter] is caused by electronic accelerator pedal. [/ QUOTE]
There is no electronic accelerator pedal in my vehicle.
08.05.2020 18:20 # 11
adatuna
If you want to ask the master, but when you are accelerating, if there is little perception of the gas in a certain place, there may be a gap in the gas wire ... check it ..
08.05.2020 18:20 # 12
gkhn08
[QUOTE = 307bursa] A normal situation, these friends don't need to look for problems, this is the case in all of the turbo cars [/ QUOTE]
It's not a car turbo, it's 1.9 straight diesel friends.
08.05.2020 18:20 # 13
HarryBlade
The liner is peeling off.
