It Happened To Me 3 Times ...!
08.05.2020 15:27 # 1
mehmet066
Friends, a warning lamp is on the display, which I do not know, I couldn't figure out exactly what it was. I have such a feature of the vehicle that you are like a bumpy bum or something. Manage it may have been in the process :)) but I could not understand. Dil Çıkarma
08.05.2020 15:27 # 2
helot
The abs must be heated, the ignition will light up then soner
08.05.2020 15:27 # 3
mehmet066
no brothers normally a strange light abs not airbag not a malfunction lamp, not a handbrake, except for the lights that turn on when the ignition turns on and goes off when running
08.05.2020 15:27 # 4
ose
The abs light but the problem of your friend indicates a malfunction if the stop lights together with the abs light while starting the vehicle with something different. I do not know the exact contents of it. Have a look at the archive that had happened to another friend before.
08.05.2020 15:27 # 5
mehmet066
stop lights up every time I run it with all the lights on the indicator.
08.05.2020 15:27 # 6
I think it talks about ESP / ASR light. http://www.tireboluforum.com/wp-content/uploads/2010/11/206gostergetablosu1.jpg
Number 28
08.05.2020 15:27 # 7
helot
Every time I open the contact, the warning lights including the stop are on and then go out.
08.05.2020 15:27 # 8
Burak07
Is such a sign? this is the esp light.
xr07 2011-05-22 07:21:08
08.05.2020 15:27 # 9
metin
Is it such a problem?
08.05.2020 15:27 # 10
metin
Change your battery if your abs light is on like this.
The bar is like a slippery floor sign on vehicles, and on some vehicles it is like (ABS).
08.05.2020 15:27 # 11
mehmet066
[QUOTE = xr07]
[/ QUOTE] Exactly this light brother esp ne yahu bidet omma output.
08.05.2020 15:27 # 12
metin
What is the model hardware of your vehicle? I don't think it's humorous, I think it is the abs light and the new battery like everybody else in its solution.
08.05.2020 15:27 # 13
mehmet066
2004 xt 1.4 16v but my car is like a full house. I don't have a problem with the battery.
08.05.2020 15:27 # 14
mehmet066
Besides, I don't even know what is asp esp. Do you have a chance to explain. Also if there is no feature, why not burn that lamp.
08.05.2020 15:27 # 15
metin
[QUOTE = mehmet066] 2004 xt 1.4 16 v but my car is something like a ful. I don't have a problem with the battery why it is because of the battery [/ QUOTE]
I did not have any problems with the battery, but the first time the abs light was on, the battery was weakened while the vehicle was waiting.
08.05.2020 15:27 # 16
mehmet066
When I turn on the ignition, all the lights are on, certain lights are on and then go out. Whatever I ask for service.
08.05.2020 15:27 # 17
sercinho
It was burning in me. I changed the battery in the first run, but it is still burning with the stop in the same first run, then it ends immediately.
08.05.2020 15:27 # 18
metin
[QUOTE = mehmet066] I don't even know what is asp esp. Do you have a chance to explain. Also if it is not available, why not burn it. [/ QUOTE]
When you say asp, you probably mean abs. The abs lamps are indicated with the vehicle symbol sliding on the road in some vehicles, while the light "(ABS)" is the same in both vehicles.
ABS anti-blocking system prevents slipping and slipping in sudden brakes. When braking, the tire releases the brake as soon as the tire locks and slips, and the brakes are not to slide but to slow down and stop the vehicle. As soon as the ABS is activated while you are applying the brake, your brake pedal will vibrate and there will be no friction sound on the iron.
ESP is an electronic stabilization program. At the corner, when the car is rolled, one of the tires brakes and the car is put back on the road.
For example, you entered a right-hand bend and the car swings to the left, while esp brakes the right rear wheel, taking the nose of the car inward and the car does not go out of the way.
easy to see if it is humorous. There is a button on the bottom left side of the steering wheel that says esp off. If there is no button, that lamp is an abs lamp.
08.05.2020 15:27 # 19
Burak07
[QUOTE = text] [QUOTE = mehmet066] I don't even know what is asp esp. Do you have a chance to explain. Also if there is no feature, why not burn it. [/ QUOTE]
+1
