IT CAN HELP .. 307 sound from the heater
08.05.2020 18:09 # 1
mrtoknctn
I wonder if the friends start to hear the buzzing sound when the heat of motos reaches 90, and have any information about the solution of the problem.
08.05.2020 18:09 # 2
mrtoknctn
no friends to give information?
08.05.2020 18:09 # 3
byx
Hi there was a situation like this in my car. The problem was in the fan motor, we removed it to the electrician and cleaned it well and lubricated it. The problem was solved. Of course I don't know my same sizzle sound.?
And if the heater stops when you press the level button slightly up and down (such as 3 to 4), it can be done from the level button ...
08.05.2020 18:09 # 4
ramtas
If the sound is buzzing, the steering pump is scratching, there may be room inside
08.05.2020 18:09 # 5
muhammed.ceyhan
there may be air in the heating line. There is a bleeding plug on the heater hose at the angle of the hood.
