it burns a lot
08.05.2020 13:58 # 1
sedat23
Friends about 2.3 weeks ago I changed the pressure pad, the car started to burn very much, could it have something to do with it?
08.05.2020 13:58 # 2
What was your car, bro? Do you peel the values that you have stuck with the previous values? The pressure pad was originally changed.
08.05.2020 13:58 # 3
sedat23
vehicle 2004 gasoline 307 pads I got myself org. valeo.Place 30 ytl in advance and 100 km. I would go now 80 km. The light is also on.
08.05.2020 13:58 # 4
hasimayaz
I think it's because he can't get used to the new pad .. actually, the pad needs to burn less after it is renewed. As there is a more comfortable grip on stop and stand ..
As I get used to the time, I believe that the fuel consumption decreases.
08.05.2020 13:58 # 5
barisaso
I changed it a month ago, no problem.
08.05.2020 13:58 # 6
sedat23
Let's see if it doesn't improve for another 1.2 weeks.
08.05.2020 13:58 # 7
sinan-s
It should improve over time ...
08.05.2020 13:58 # 8
Eastanbul
[QUOTE = hasimayaz] I think it's because he can't get used to the new pad .. in fact, the pad needs to burn less after it is renewed. As there is a more comfortable grip on stop and stand ..
When I get used to, I think you will get better!
Although it is original, there is no longer a product that fits completely in its original place.
cheap costs, cheap craftsmanship, cheap molds, firms making money, high profit margins are all built on it!
(don't get me wrong, I'm talking about materials, not for masters)
08.05.2020 13:58 # 9
gokan
the pressure is not in the lining but the filter is in the injectors
08.05.2020 13:58 # 10
[QUOTE = gknb85] the print is not on the lining but the filter is on the injectors to look at the filter [/ QUOTE]
I agree with Gokhana, if the filter is clogged, there is dirt in the injectors, as far as I can see, these are the ones that are waiting for the depot to fall to the bottom since you see the light.
The fact that the tank is full in terms of making measurements healthy, the load condition in the vehicle, the weather conditions and the changing fuel prices are important factors.
08.05.2020 13:58 # 11
Could the petrol price difference mislead you
08.05.2020 13:58 # 12
Is there any problem with the departures of the vehicle after changing it? Where did you think it was because of pressure?
We write comments without seeing them, we do not want to inform you incorrectly, it would be better if you give us more details on this subject;)
respect for the man ...
08.05.2020 13:58 # 13
I need to burn less.
The problem is elsewhere.
08.05.2020 13:58 # 14
sedat23
On the contrary, there is no problem in the car, as I press it, the car is very comfortable, but as you say, I do not buy gasoline without seeing the light.
08.05.2020 13:58 # 15
If the pressure pad is zero, it draws its own axis first.Then it sits on that little line, there is no waste of time. As a result, there are 2 weeks.
08.05.2020 13:58 # 16
oguzhan29
use it a little as your friend says, try it for 2-3 weeks.
