Is this the fan sender? (Photo)
08.05.2020 18:15 # 1
Ssedo
the master says that you changed the fan sender, but the temperature rises to almost 100 again. do you think it has changed? pretty dirty worn & nbsp; does not look like new but I wanted to ask you
Link
08.05.2020 18:15 # 2
Ssedo
Also, the LPG does not light up (atiker) because there is no gas in it, or did they forget to wear something? we will take it again monday but i wondered
08.05.2020 18:15 # 3
C@GL@R
this doesn't look like something new, but the fn doesn't look like the sensor, is this an oxygen sensor? : D but if it was changed, the upper part of the socket changed the bottom, the part that entered the engine
C@GL@R 2014-01-26 19:36:52
08.05.2020 18:15 # 4
kursat3006
If the tube indicator light did not come on while the vehicle was on, there would be a problem if the button did not come on again. You can not understand whether it is gas or gas.
I don't know if he is a fan muster, but the temperature is not normal for him to see 100 on winter day.
08.05.2020 18:15 # 5
burglar08
Temperature sensor.
08.05.2020 18:15 # 6
herry
The green piece is not like the new one.
08.05.2020 18:15 # 7
volkanC2
I changed the temperature sensor of my C2, where the same happened and the same top was in the shape of a green socket such that the 206 and C2 engine parts are almost the same, I think this temperature sensor is `` I don't think it's new. ''
08.05.2020 18:15 # 8
Ssedo
thanks friends say that service is trying to stutter us change it insistently & nbsp; I will open my mouth after showing it to another master on Tuesday and I am not sure, neither morale nor anything else due to such dishonests
now our problem is the temperature indicator suddenly it goes down to 0, it turns out to 100, whereas the engine was newly built, it probably did not change the customer, it does not give invoice. If the incident gets tough, can I complain about that I would not bill?
08.05.2020 18:15 # 9
Burak
Of course, you can complain, it is your right, it is a legal obligation. In return for your work, you have to give you a receipt and a document. When my car had a problem in the seat ibiza thermostat it changed. You can look at the link below.
http: //forum.peugeotturkey.com/forum_posts.asp?tıd=26561&title=hararet-musuru-hakkindacozul was Reviews
08.05.2020 18:15 # 10
Ssedo
Hodja, where exactly is the thermostat? I'm going to take it from the masters now and change it myself. Damn them.
08.05.2020 18:15 # 11
Ssedo
friends, as far as we understand now, there is a green brown sender, one is the heat and the other is the fan sender & nbsp;
what does the heat sender do?
what is the thermostat? I'm asking & nbsp;
fan is turning the fan on and off, okay, which one shows the temperature in the instrument panel?
08.05.2020 18:15 # 12
[QUOTE = Ssedo]
Our current problem is that the temperature indicator suddenly drops to 0, whereas the engine is newly built & nbsp;
I had this problem with me, but from the heat sensor, etc. not. The source of this problem is the thermostat. Meanwhile, that green material is quite an old piece.
08.05.2020 18:15 # 13
karacakrc
It may be overheating. The brown that appears under the dipstick must also be oxygen.
08.05.2020 18:15 # 14
eren106
The green socket is the orig.electric connection of the vehicle, so it does not change untouched.
08.05.2020 18:15 # 15
The piece you showed is overheating.
If he says he changed that piece, it certainly hasn't.
the fan sensor is on the fan. not over the engine block.
