Is This Sound From The Engine Normal
08.05.2020 21:12 # 1
samizeldestan
I bought this vehicle about 2 years ago. I just noticed a sound like that. I don't know if it existed before. I shot the video while the engine was running. Can anyone understand?
Video: [TUBE] V3A0aFIejaA [/ TUBE]
08.05.2020 21:12 # 2
pusutr
It looks like the noise of the bearing that is about to circulate or deteriorate.
08.05.2020 21:12 # 3
samizeldestan
What should I do? Does it cost too much?
08.05.2020 21:12 # 4
pusutr
If it is circulating, I recommend you replace it with the timing set. I would even recommend you to change the timing and alternator set together.
I think around 2 thousand TL with the workmanship.
In short, you have done heavy maintenance.
Or he can go to a good master, find the source of the sound with a stethoscope, only by intervening in that area and offer a temporary solution.
08.05.2020 21:12 # 5
samizeldestan
I took it to a master today and said that the sound is normal, there is an engine on the left side in the video, I think the sound related to the steering is coming from there.
08.05.2020 21:12 # 6
aritizm
Sir, I get the same sound, I know that it comes from the steering pump, but just in case it is good to consult a good master, perhaps we may be ignoring an existing problem.
08.05.2020 21:12 # 7
samizeldestan
The master said the voice is normal. If I am a master, he is one of the best masters in the industry. There is one more thing I want to ask. Where do we put the radiator water in this vehicle?
08.05.2020 21:12 # 8
ersin61
Radiator is taking water from the reserve water tank.
08.05.2020 21:12 # 9
samizeldestan
So where is this spare water tank? There is a tank on the left when I open the hood. It goes to the radiator in the pipe, but when I open the lid and look, there is oil.
08.05.2020 21:12 # 10
ersin61
I don't know where 2.0 is 1.6 hdi when it comes to oil on the left side, if it is dark or light, blue or red antifreeze colors are black, probably the gasket is burning and it gives oil to the water.
08.05.2020 21:12 # 11
samizeldestan
08.05.2020 21:12 # 12
samizeldestan
That's what I'm talking about
08.05.2020 21:12 # 13
ersin61
It looks like antifreeze water, but of course you should see someone who understands if you have a doubt.
08.05.2020 21:12 # 14
samizeldestan
Thank you. You have to ask a master. Peugeot was very different to me.
