is this oil level normal? I wonder
08.05.2020 17:07 # 1
gngburak
is exactly where the oil level is in this line.
& nbsp;
& nbsp;
& nbsp;
08.05.2020 17:07 # 2
It is permissible to be anywhere in the scratched area. Whether it is below or below. However, this should not be outside of the nerves. The location of yours is a little below half but normal. By the way, what a beautiful flag is waving behind.
08.05.2020 17:07 # 3
hakan38
bro you are superb you take a photo of oil stick :) normal brother is normal. even the most appropriate level
08.05.2020 17:07 # 4
gngburak
What I do is the tool, it has been 1 year, I have learned almost everything, thanks to this form, I did not know when I bought the tool
, I went randomly, but now
nobody can knock a faulty peugeot
08.05.2020 17:07 # 5
gngburak
In which country is there such a meaningful flag ..... "Clap"
08.05.2020 17:07 # 6
tellotello
A little diminished, no problem, but how long has it been time to put oil?
08.05.2020 17:07 # 7
goktug
the level should be a little higher, the sister decreased a lot.
08.05.2020 17:07 # 8
bahcekapili
You can not see if the vehicle is reducing oil by looking at this bar, friends. However, you realize that the oil level is normal, the oil level is normal.
What you need to do is to look at the level of the line when you add oil to the vehicle in maintenance (how many liters your vehicle gets). Then, when you look back after 2000 - 3000 km, if the level has dropped, you can say that the car has decreased the oil, but there is definitely no problem between these two lines.
& nbsp;
While looking at the oil level, it is more accurate to park the car on flat ground and look the next morning. The oil level is never observed in the hot engine. It is necessary to wait at least 1 hour. As I said, if you want peace of mind, stop in the evening and see in the morning.
& nbsp;
< . When I put 5 liters in my new vehicle, 2.0 HDI, the oil level seems to be obvious. By evaluating this, it can be concluded that when looking at the oil level of both vehicles at 5,000 km, 2.0 HDI decreased the oil, which would be a false assumption.
bahcekapili 2012-11-14 12 : 49: 21
08.05.2020 17:07 # 9
gngburak
Thank you very much for your comments ....
08.05.2020 17:07 # 10
Serkan
As my master says in the picture, my oil level usually falls slightly above the middle
Reviews
08.05.2020 17:07 # 11
gngburak
[QUOTE = Serco05] As my master says in the picture, my oil level usually stands a little above the middle
[/ QUOTE] now it has been very descriptive thank you very much
