Is there anything like this happening to you? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:56 | # 1 |
GiTaRRa |
I checked everything, I couldn't find a different sound like cover sound |
| 08.05.2020 16:56 | # 2 |
So, when you press the drain, does the sound stop or does the sound continue while you are on the move?
| 08.05.2020 16:56 | # 3 |
Could it be from shock absorbers? & Nbsp; |
| 08.05.2020 16:56 | # 4 |
GiTaRRa |
I have nothing to do with the clutch, it is not depreciated, because you hit the two plates together, just like the sound of the open cover for the sound of the timbre. I hit my hand to him, it sounds similar, I couldn't solve a kind of master. If we were to be such a master, oooo said: S
| 08.05.2020 16:56 | # 5 |
ssertbakan |
Did you change the timing set before the sound came? & Nbsp;
| 08.05.2020 16:56 | # 6 |
I think the sound comes from the exhaust pipes. The same thing happened to me in my old car ..
| 08.05.2020 16:56 | # 7 |
GiTaRRa |
timing set changed 4 It happened for 5 months.
| 08.05.2020 16:56 | # 8 |
I suffered from sometime in the same trouble, the screw inside the engine ear was broken, so the engine was touching the protection plate and making noise. There may be such a problem in yours.
| 08.05.2020 16:56 | # 9 |
metin |
Did you look at the bend? it can also be from the exhaust port.
