IS THERE ANY USES FROM THIS PRODUCT?
08.05.2020 14:53 # 1
Sinan
http://www.hepsiburada.com/liste/nnt-bor-power-nano-teknolojik-ms-250-motor-yag-katkisi-092090-/productdetails.aspx?categoryid=26005&productid=otm092090
My vehicle was 2004 model 206 hdi 130.000 km and I ordered this product online. I read 100 - 150 of the comments there before I gave them and almost all of them gave positive cvp. Does anyone use this product? What are the differences, positive negatives, if any?
08.05.2020 14:53 # 2
rifatseker
I used my old car, it was 144,000 km and the engine was running a little noisy. After using this, it seemed a little more relaxed to work, I felt the differences in the engine of the small vehicle, even if there were not such huge differences. A little bit more serial, a little quieter.
08.05.2020 14:53 # 3
mimit
I definitely use a useful product. I add the additive every 20,000 km regularly, you will only get a much better result if you have a carbon clean on your car and then use this substance when changing the oil. gives cvp.
08.05.2020 14:53 # 4
BAHTIYAR
this is the first brand on the market and it is the best quality. I used it in my old taunus. It was a relief in the first run and sound. I couldn't find it in 307 me.
08.05.2020 14:53 # 5
ggokayy
We also use this product, it definitely works.
08.05.2020 14:53 # 6
I put the ms-250 silver flour into my vehicle in line with the instructions. I traveled about 3000 km. As far as I feel, the engine is running softer ... the cecol 2010-09-25 00:48:14
08.05.2020 14:53 # 7
BuRCaK
Didn't you sell Sister car? what's up?
08.05.2020 14:53 # 8
Who did not sell?
08.05.2020 14:53 # 9
BuRCaK
I said Sinan, brother :)
08.05.2020 14:53 # 10
Onur
very close friend said the service chief put all the masters in maintenance, add the engine master chief at the peugeot authorized service, said the oil definitely, the oil change is close, let's put it already
08.05.2020 14:53 # 11
@honor
If you buy s-250 gold instead of ms-250 silver, you will be more effective. Also, if you want, put a box of motor wash inside the oil before putting this product on. work for half an hour like that. then, if you drop it directly from the oil pan and cut it into money, put it with full synthetic oil. in this way it will give you more useful and long-term protection. It is expensive as an oil, but I can fix the fiber to 1 new fiber 0-40 (around 80tl). If you say it is cheap, you can use total quartz 9000 0-40 (55tl) ...
the cecol 2010-09-25 14:22:38
08.05.2020 14:53 # 12
iibrahimm
I used it, I have 307 1,4 hdi I used it, I saw the benefit, put it in the gearbox, there were voicing sounds, there was a noticeable decrease.
08.05.2020 14:53 # 13
saint007
Hello,
& nbsp;
I added it to my 2004 model 307 1.4 HDI vehicle at 135,000 km, and I think I saw its benefit. , but you should know the vehicle very well in order to feel this difference. I put the contribution about the product, the sound of the engine has changed, the fuel has decreased, the traction has increased, taking into account the comments, most psychological. As I wrote above, the product shows its effect only after 500-1000 km. It is hard to notice that it reduces fuel, but I felt it was more comfortable for the vehicle to operate under 1900 revolutions before the turbo started.
& nbsp;
One of the most important points when adding this additive after oil change is that the oil level in the engine is max. Be very careful not to go above the level because this is more dangerous than missing oil.
Website Advertising is prohibited.
& nbsp;
Selamlar
GökhaN 2010-09-29 23:46:50 < / editdat a>
08.05.2020 14:53 # 14
oguzhan29
Let's say what positive effects it has created to my vehicle.
