Is there any problem missing 1 bolt
08.05.2020 16:52 # 1
goktug
when we removed the wheels for rot balancing today, we saw that a stud was licking and we threw it out because it was idle. I think we couldn't find any other suitable bolts and the bed was licking too. The master says that the complete discs vary from 70 to 80 rubles? Do you think the car causes problems with 3 wheel bolts? I hope the tire will not jump. He said nothing would be comfortable for the master, but?
08.05.2020 16:52 # 2
BULUT06
the masters will give you the opportunity to entrust you with the wish that you will have a slight hunger in the place that will not be attached to the wheel at the distance of 100 km.
08.05.2020 16:52 # 3
goktug
I have it done by me. But when the master said, never mind, let me think ...
08.05.2020 16:52 # 4
GiTaRRa
do not look at the master, they dont let the donkey die intact. "
08.05.2020 16:52 # 5
Kemanyak
Never mind, it works. We travel on 4 screws. 1 means 25% lack of strength. Other studs are loaded more than they should. Go, I want to make a turner open a nest here and take it. I would check that there would be a related topic in the forum. Slot opening process is very easy and 30 TL. Don't risk yourself for 30 pounds. Again he is a master !! Don't entrust your vehicle. Kemanyak 2012-06-22 00:47:45
08.05.2020 16:52 # 6
xpyhre
I strongly recommend you get it done. Nobody wants to hurt you for 100 TL. After all, I know what will be the iron stack? the master drew my destiny whether or not he would know anything. & nbsp;
08.05.2020 16:52 # 7
EmSul
3 of the wheel bolts of the left front wheel had been licking. Do not neglect one or more of yours, even if you do not change it, make a slot for the turner again
08.05.2020 16:52 # 8
metin
Your life is not worth less than 70-80 TL, I think you should have it done. & Nbsp;
08.05.2020 16:52 # 9
toga406
You are giving 20 TL, you are going to open the lathe for the screwdriver, you get 5 TL for the same nut and they are wearing it.
Of course, there is a problem.
Doesn't life have a value that is so important that it can not be a joke that it doesn't have the value of a wheel bolt so that your or other people's life
please immediately it turns on the turner in a very simple 10 minutes.
When changing tires, the rubbermen probably couldn't adjust the torque, licked, I went right out of my pocket
& nbsp;
08.05.2020 16:52 # 10
tigerland
. 206_XS 2012-06-23 10:24:11
08.05.2020 16:52 # 11
tigerland
I had a bed around me. Thanks to the tire man, the rim was squeezed with a pneumatic machine before the wheel was seated, he pulled it back and said it was a bed :) I became a nerve cube, of course & nbsp;
I went directly to the lathe. He pulled the guide into 2 slots and the other two bowed. 4 Studs continue. He kept 20 TL but I took the piece off. The price of the port is 140 TL, apart from zero discs, this piece is also master, I guess he thinks with the disc :))
206_XS 2012-06-23 10:24:24
08.05.2020 16:52 # 12
goktug
thanks you made friends, as you say I made a slot in the lathe, I put on a new nut ...
08.05.2020 16:52 # 13
MagicPerformance
Letting the missing be a bit more or less squeezed than others, you should find a solution immediately.
08.05.2020 16:52 # 14
toga406
Look, go!
put on the bolt immediately.
Look, go!
"Hug"
& nbsp;
08.05.2020 16:52 # 15
xpyhre
[QUOTE = toga406] Look, go!
put on the bolt now.
Look, go!
"Hug"
& nbsp;
"LOL" "LOL"
08.05.2020 16:52 # 16
safakhan
life is so cheap in this country ...
09.06.2021 15:43 # 17
kapadok
I stayed, friends, the master said, nothing will pass. But it just doesn't pass.
Aha such I found it on a resource. Severely Flawed
