Is there any harm to the sports broadcast front team? (106)
08.05.2020 17:22 # 1
tanzara
SA friends, I have 106 Quicksilver. It sounded from the front of my vehicle and from the steering wheel. I had it last week. Then, I had a 5 cm eibach sports spring on my vehicle. The master said to me that if you wear a sports bow, the front team will deteriorate more quickly, you will have to get it done again. How true do you think the master said. So does the sports spring really hurt the front team. For my friends wearing sports bows, I say, `` Does your vehicle have such a thing? '' I would really apreciate if you help. Thank you in advance.
08.05.2020 17:22 # 2
esmer_38_tc
Hi, unfortunately, it is too early to deteriorate.
08.05.2020 17:22 # 3
sedataksu
The front tool breaks down more quickly, which is a bit about use. It depends on your use of pain.
08.05.2020 17:22 # 4
rockwaryumm
It may deteriorate more quickly, as the yaw is reduced. How much did you handle the steering?
08.05.2020 17:22 # 5
az57
Since the fabricated dimensions are in comparison with the original springs, when the sport is lowered, when the vehicle is lowered, it increases the pressure on the front swing and the z-rod, thus shortening its life. But of course this does not mean that it will spoil immediately. 106 & nbsp; or not like a retirement car. & nbsp; I wouldn't recommend it if you are going to use it on a very bad road where you will use it. I have been using 5 cm for 3 years. I changed 2 z rods from the original service. I bought 20 tl & nbsp; 1 right swing left left & nbsp; I changed the bottom rot 20 - 20 & nbsp; = 40 tl.
08.05.2020 17:22 # 6
tanzara
[QUOTE = esmer_38_tc] slm, unfortunately, it is going to start to deteriorate so much .. you made the steering pump [/ QUOTE]
teacher, I made the box, not the steering pump
08.05.2020 17:22 # 7
mermi6458
how much do they broke the steering wheel
08.05.2020 17:22 # 8
tanzara
250-300 with labor
