Is there any harm to the sports broadcast front team? (106) |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 17:22 | # 1 |
tanzara |
| 08.05.2020 17:22 | # 2 |
ewt it has not faded correctly, but if you use it carefully, there will be no problem.
| 08.05.2020 17:22 | # 3 |
bysarsinti |
The z rods in me are gone because of the sport bow, brother. If I find a path and change it, I will renew the rods. & nbsp; is correct by the master, but true if the path you use the car is very bad. but if you use it carefully and take care not to enter the pits, there is no problem.
| 08.05.2020 17:22 | # 4 |
tanzara |
I thank my friends who answered. I am waiting from my other friends :)
| 08.05.2020 17:22 | # 5 |
_PunisheR_ |
If you use it carefully, depending on the road conditions and usage, you will not have any problems.
| 08.05.2020 17:22 | # 6 |
the sports spring makes the bottom of the vehicle close to the ground, the closer the vehicle is to the ground, the higher speed steering dominance on the highway will be so comfortable. it also deteriorates quickly in suspension.
| 08.05.2020 17:22 | # 7 |
impact |
I think it is harmful if you use it slowly because it reflects the reactions to shorter and lower levels, but it does not necessarily cause trouble, but there is another pleasure in 106.
| 08.05.2020 17:22 | # 8 |
EErgul |
the simplest axis changes the angle of the gearbox. The angle of the tulips is changing. it doesn't stop as it should. mechanical gear, after all, the teeth do not stick together like the original. That's why it shorten its life. so you know the quality when the part is changing.
