Is there a trip computer?
08.05.2020 16:04 # 1
tugay307
arkadaşlar bende 2004 model 307 1.4 hdi xr var kullanma kılavuzuna göre b ekran var bende kullanma kılavuza göre yol bilgisayarı var yani arac ne kadar daha gitcek falan öyle bilgiler var yazıyo kitapçıkta ama arabada bulamadım radyo saat tarih hava sıcaklıgı falan yazıyor birtek bilginiz varsa yazabilirmisiniz eger varsa bilgisayarı nerden bakabilirim o bilgilere.
08.05.2020 16:04 # 2
altantezcan
there is a button on the wiper arm, like the horn in old cars, the screen will change as you press it
08.05.2020 16:04 # 3
Some vehicles have a display infrastructure but need to change the wiper arm to activate it.
First of all, you should try to check if the information on the screen has changed by pressing the button on the end of the wiper arm. If there is no change, you will need to change the handle to activate the trip computer.
08.05.2020 16:04 # 4
[QUOTE = Berkay] Some vehicles have a screen infrastructure, but you need to change the wiper arm to activate it.
In some vehicles, the opposite happens, there is an arm, but it is not visible on the screen.
Note: my vehicle is also 2004 307 XR 1.4 hdi
the mustafa_usl 2011-08-29 21:57:06
08.05.2020 16:04 # 5
Interestingly, my father's car was 2005 307 1,4 HDi XR. When we got zero, the trip computer was actively working.
08.05.2020 16:04 # 6
tugay307
I am pressing friends but it does not happen. There is no button on the end of the wiper arm. Just pressing it makes the click sound die?
08.05.2020 16:04 # 7
[QUOTE = brigade307] I'm printing friends but it doesn't happen. There is no button on the end of the wiper arm. Just press it makes the click sound die? [/ QUOTE]
If you are comparing it, I peel it off, the button on the end of the wiper arm is similar to the button on the end of the signal arm. I guess you don't have a button, just a cover. There was talk about how this part could be modified and turned into a button in the forum.
08.05.2020 16:04 # 8
sserhat
http://forum.peugeotturkey.com/forum_posts.asp?tıd=16691&title=peugeot-206-yol-bilgisayar-com2000-tu-yapm
Brother is for 206, but if I want 307, I don't know.
08.05.2020 16:04 # 9
metin
[QUOTE = sserhat] http://forum.peugeotturkey.com/forum_posts.asp?TID=16691&title=peugeot-206-yol-bilg Bilgisayar-com2000-tu-yapm
The signal arm of the 206 and 307 must be the same, so I know that the two fit together.
08.05.2020 16:04 # 10
It is an interesting situation when there is no button but a sound is heard.
If you put photos of the screen and wiper arm, we can help more.
08.05.2020 16:04 # 11
metin
[QUOTE = Recipient] [QUOTE = brigade307] I press friends but it does not happen No button on the tip of the wiper arm just makes the click sound die when pressed? [/ QUOTE]
in some it may be that the end of the arm is changing, not the complete signal arm. detailed information is available in the forum.
08.05.2020 16:04 # 12
[QUOTE = text]
hardwarehaber also sent a friend video. In some models of the 307s, as you said, that tip is changing. I removed that part for 206+, but it wasn't like that. There was a strip and it was not removed. I never opened the other pin part. I removed the end cap and activated the button event. It would be wrong to say something without looking in the 307s. Carefully, you can remove the small cap at the end and try the button with the help of something thin.
On the other hand, if the tip needs to be changed, it is better for the friend to contact someone who knows.
08.05.2020 16:04 # 13
tugay307
08.05.2020 16:04 # 14
tugay307
this is the arkadşkar arm
