Is there a place where I can attach a cruise control in Bursa |
| 08.05.2020 14:53 | # 1 |
2006 model 307xt, I want to have cruise control, cruise control on my triptonic gear. The official said he could not service. Is there a service or a special service that I can get help with in this regard. Thanks. |
| 08.05.2020 14:53 | # 2 |
coyote26 |
I don't know the scholarship, but you can have it installed at Peugeot authorized services.
| 08.05.2020 14:53 | # 3 |
Hello everyone, they said that it is possible to install Nilkar automative from authorized dealers in Bursa, but they could not, because they were instructed that they should never be installed from the headquarters. On the same day, when another official went to Şançelik, they said that they would respond after the necessary checks. However, after their check, they said that my vehicle was not suitable for CC and that assembly could not be possible. My vehicle is a 2006 model XT triptonic. Do you have a friend who has the same model vehicle and has CC installed and using it? Also, can we have this process done outside the authorized services. Good evening.
| 08.05.2020 14:53 | # 4 |
If the car control system is can-bus, it can be fitted outside. If you want to have it installed, there is a shop called Peugeot Garage in the small range of the building credit bank in the small industry.
| 08.05.2020 14:53 | # 5 |
At what speed can the gasoline be engaged in manual gears? I think 4 and 5 as gears
| 08.05.2020 14:53 | # 6 |
thank you . Let me look at the place where you gave the address, I will write the result from the forum.
| 08.05.2020 14:53 | # 7 |
Hello friends , I had CC installed on my 2006 xt triptonic gear. It works perfectly smoothly and smoothly. Especially on the long road, it also provides extra fuel savings, + keeping your speed stable and not making unnecessary accelerations.
| 08.05.2020 14:53 | # 8 |
good luck. great comfort
| 08.05.2020 14:53 | # 9 |
frk_206 |
What is the cost of installing a CC? Is it practical and affordable on manual gear vehicles? Would you recommend to wear it? Finally, is there anyone in Kayseri that will do this job clean?
| 08.05.2020 14:53 | # 10 |
It is not yet available for 206.It is subject to 1.4 motr
| 08.05.2020 14:53 | # 11 |
I wonder how much it costs ?????
| 08.05.2020 14:53 | # 12 |
It costs 150 TL in total.
| 08.05.2020 14:53 | # 13 |
PCcolog |
There is İL-BE automotive in the 9th Block in Small Industry as a service in Bursa. Phone: 443 33 52 / 0- 535-636 48 97 İlhan or Bekir bey var. Former ŞANÇELİK employees. In other words, he knows Peutos like his palm. I call them a consultant. I am very satisfied, there is no need to go to the authorized service. |
| 08.05.2020 14:53 | # 14 |
Hello, I have a 307 vehicle. On the left side of my vehicle, there is the same entrance as the entrance of the radio control controller. They said also my throttle is not electronic
| 08.05.2020 14:53 | # 15 |
Alicilik |
1 vehicle is not canbus, there is also a canbus makeup case. If 2 accelerator pedal wires, electronic speed stabilization will not be possible. |
| 08.05.2020 14:53 | # 16 |
I think I misrepresented a post that I have read, that is, is it not a stabilizer at all?
