Is there a peugeot electronics europe
27.07.2020 18:42 # 1
Nightvision
Hi friends. I cannot find a pejo electronics specialist to show my vehicle, does anyone know on the European side of Istanbul? There is garaj58 in Maslak, but whenever I go, the master says I'm full. I am already sparing time from idle power. The trouble in the vehicle, the vehicle fell off the tug, fainted on the ramps and jerked, especially in low periods. The fan also works continuously. I renewed the oil pressure oiler and the spark plugs. Either the cooler box or the catalyst malfunction when connected to the computer. The exhaustist looked at the catalyst with a camera, it looked like there was no problem, but you have to stick it in and look to be sure. He said go to the special service electronics shop. And blah blah blah 2011 308 1.6vti gasoline, no LPG.
28.07.2020 09:07 # 2
http://birlikotoservis.com/fotogaleri.php teacher one here and also Önöz otomotiv https://www.google.com/search?safe=strict&rlz=1C1GCEU_trTR833TR833&sxsrf=ALeKk00W-nHIRbL9kS-q6%8Rb = B6N B6z%% +% C3 + esenyurt automotive OQ = B6N% C3% +% C3% B6z automotive & gs_lcp = cgzwc3ktywıqargbmgqııxanmgııadııcaaqcbaheb4ycagaeagqbxaemggıabaıeacqhjııcaaqcbaheb4ycagaeagqbxaemggıabaıeacqhjııcaaqcbaheb4ybagaeb46cggjeladeccqiwnqrltyrltg1xhoaxaaeacaaxuıaxusaqmwljgyaqcgaqgqaqdnd3mtd2l6uaecwaeb & sclient = psy-ab
11.08.2020 13:18 # 3
Cenk88
Sir, I have more or less the same problems, did you solve the problem?
12.08.2020 15:53 # 4
maximusti
I never had any shopping or transactions before, but I was recommending this place, which I knew from a few different forums and outside a few forums. If you are close, I would say get an idea. Şeker Oto - Bayram ŞekerCevizlibağ Yedikule Çırpıcı Yolu Fırat Oto Sanayi Sitesi No: 77, Topkapı - Zeytinburnu, 34020 E-5 is very close to the yacht,
07.10.2020 14:54 # 5
Nightvision
Sir, I am turning at night, but I could not solve it. The fault light came on and stopped, it was said that there was a problem in the electrical installation, I could not get it done for a while because the man said I was full. Then I took the engine in my lap. I spent 15500 TL and had the motor built. At the moment, the fault light is on again and another electrician says there is a disconnection in the installation. The vehicle still has an electrical and electronic problem. What did you do?
08.10.2020 09:40 # 6
Cenk88
off teacher, I am very sorry, get past it, I have researched a lot in domestic and foreign forums, and as you said, I came to the conclusion that the problem may be due to cable breakage, disconnections in the sockets, breakdown of the fuse boxes due to contact with water or a sensor sending bad data and disrupting the CAN communication, on the battery When it rains on the fuse box, water drops, maybe it is broken ... the car is overheating while climbing the slope, I think the reason for this is that it cannot receive data from some sensors due to the CAN failure and it cannot calculate the instantaneous torque required for the vehicle, and more gasoline is pumped into the combustion chamber. I showed it to many places, these vehicles are like this, they said use it like this, but the vehicle gives more than one CAN failure starting with the letter U, I cannot use it comfortably when there are these, I will show it to the auto electronics shop a few days later, let's see what it will say. Was the vehicle 4-speed automatic, sir?
