Is there a master who knows how to practice 206+ throttle? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 206+ | |
| 08.05.2020 15:43 | # 1 |
hunterakon |
Friends 206+ 2011 Do you have a master who knows how to practice the throttle of my vehicle? If you ask me why you want to have it done, there are some problems with my vehicle in another matter and abc pejo say they do this operation, I want to find out whether it will be done on my vehicle every day or not. I know how to do it in opels, but I don't know how pejoes give information in the service. |
| 08.05.2020 15:43 | # 2 |
The other name of this process is adaptation and is done with pp2000 computer
| 08.05.2020 15:43 | # 3 |
hunterakon |
[QUOTE = CeCoLi] The other name of this process is adaptation and is done with pp2000 computer [/ QUOTE] Hmm, there is a difference with the tools I know, but I was thinking something mechanical. I thought I had a spontaneous operation such as 10 times press the brake, press the brake, open the ignition etc.
| 08.05.2020 15:43 | # 4 |
metin |
koliva is an excerpt from my brother, Calibration means synchronizing the current position of the butterfly with the brain. If you play on the spot while you are cleaning, you may need to calibrate. Calibration is done simply. The vehicle is stopped. Then the starter is pressed and run for 10 seconds. Then it is stopped for 10 seconds. This process may need to be repeated several times. Good luck with.
| 08.05.2020 15:43 | # 5 |
hunterakon |
Thank you very much, I think it will be useful to try |
| 08.05.2020 15:43 | # 6 |
metin |
I hope will be,
