Is there a competent c4 master on the Anatolian side
08.05.2020 21:23 # 1
S1m4k
Hi everyone, I just joined my car 2012 model 1.6 hdi 85 thousand citroen c4
I just bought it and they recommended that they change in the appraisal. I'm adding
How much does the amount generally include labor?
And is there any master you will recommend close to the Anatolian side of the cotton
Thanks to everyone already
08.05.2020 21:23 # 2
ismailkaya
First of all welcome market as I wrote below in bursa
1- Wiper water tank 350 TL what is needed, if it is cracked, patch with silicone seal adhesive
2- rod balan setting 100 TL (go to the rod balancer)
3- If you jar the battery, it means that the charcoal of the charger will change. auto electrician to go
4- Front brake pads are 100 TL.
5-V apricot will be changed. Change the V-belt to one of the mechanic. The set of the belt holds a bit with the tensioner bearing 50 -100 crafting titar.
6- Let's come to the kran seal, I do not know it, the vehicle can be up to 2500 ways of diesel service. If V-belt is lubricating, repair is required (I recommend the authorized service for repair)
7- Charging and starting maintenance maintains 500-600 TL
08.05.2020 21:23 # 3
S1m4k
how expensive it is. Is there any suggestion for the Anatolian side citroenci?
08.05.2020 21:23 # 4
I wish you to use your vehicle without any accident. If you do all the transactions, you will need to review 2000 TL.
08.05.2020 21:23 # 5
S1m4k
front linings 100 tl
wiper can 100tl
battery voltage loading 30tl
v strap 80 tl
100tl of labor
friends pendik auto industry citroen captain and eagle auto industry team is the average price i get from auto. don't you think? the prices you gave came to me
