Is there a 206 rear door speaker installation?
08.05.2020 19:06 # 1
erdemchetin
Friends 2004 hdi xline, there are no speakers in the back doors, I decided to install it, but is there a ready installation in the back door? If you do not suggest where to pull the cable or if the original models of the rear door speakers, where do they go?
08.05.2020 19:06 # 2
monalos
I didn't know how to tell: D
There is a socket similar to the picture below, between the door electrical parts and the chassis on all doors, the speaker electrical parts pass through this socket.
First of all, if there are extra wires to unplug the tiles, check if there is a speaker, if it is for the speaker, it is very easy but it is also easy.
First, let's unscrew the door trim, then disconnect the socket that I showed.
When you pull the upholstery to which the seat belt is fastened, it is disassembled from the inside, but it is not taken out completely, let me tell you, then pull the cable from here to the lower carpet floor.
Then remove the door inner wicks, place the cable under the floor, and come under the carpet to the back of the tape and make speaker connections.
I couldn't explain more than it was not visual.
Socket I mentioned above:
08.05.2020 19:06 # 3
monalos
I can tell you in the form of a video on Wednesday. Then you know for sure, so you can handle it smoothly.
08.05.2020 19:06 # 4
erdemchetin
Thank you. As far as I understand, if there is no installation, we will do as you say. I am not in a hurry, I have to install it first. I can wait.
08.05.2020 19:06 # 5
monalos
Okay, no problem. You will do the process when you make a led under the door trims as a speaker operation. The process is not too difficult. Sometimes I will take it off and do it again.
08.05.2020 19:06 # 6
talip206
Greetings I have the same situation. There were no speakers in the back. I went to a place that made a sound system, their installation is ready inside, we said we just plug in the speaker. but I said stay because he wants a lot of money. The man did not hear from the front left speaker and asked for 100 TL. I went too, I bought the original speaker for 20 TL, I installed it myself Smile
08.05.2020 19:06 # 7
oguzhan29
I had the x-line wiring in my vehicle, I installed jbl 608c component kit on the front doors.
08.05.2020 19:06 # 8
Samet Cetin
Hello friends, I want to install speakers on the rear doors of my vehicle, but there is no installation, monalos my friend can post videos, etc. It would not be bad if we share something for how. I will do it soon but if there is a little information it will help me. How do we pull the cables from behind the tape and so on.
08.05.2020 19:06 # 9
Samet Cetin
I can even do it if you share how the led event is done.
08.05.2020 19:06 # 10
samet206
Normally, even if there are no speakers from the factory at the rear doors, the cable harness is likely to be pulled, and most of them exist.
