IS THE THROAT BUTTERFLY CLEANING WITHOUT REMOVAL?
Homepage » PEUGEOT MODIFIED PLATFORM » 308
08.05.2020 19:48 # 1
ozgurkso
Hi friends, when the engine heats up and decreases idling when lpg is in my 308 1.6 vti car, it stops every once in a while. Waiting for your comments I will act according to your comments.
08.05.2020 19:48 # 2
No, why should my teacher break even the authorized services? the best is to disassemble and clean it well. but don't forget to adapt.
08.05.2020 19:48 # 3
ssakyel
Nothing happens if they clean like a human. LOL They usually clean in place to avoid hassle. It can be a bit more expensive to disassemble the tray.
08.05.2020 19:48 # 4
okan77
Adaptation etc. does it have to be done?
08.05.2020 19:48 # 5
ssakyel
If it is removed, if its socket is removed, it is necessary to adapt again.
08.05.2020 19:48 # 6
Suleyman
Teacher, there is no problem, even after cleaning, the sound of the vehicle improves and its performance increases.
08.05.2020 19:48 # 7
ozgurkso
I like peugeot, but if I disassemble the throttle in a place that is really laborious, it is not possible to see whether the master put the screw in full or tightened the clamp. I suppose we will get the special throttle cleaner, and I would like to ask for a special throttle cleaner. Do you think butterfly contamination is normal in the vehicle?
08.05.2020 19:48 # 8
betaser
Hello, removing the socket has nothing to do with adaptation.You remove the socket on the engine when you lock the doors of the car while the hood is open, and remove or replace or replace every socket on the engine. Nothing will happen.
08.05.2020 19:48 # 9
mimit
In the operations performed without dismantling, every dirt on the part goes into the engine? So I am for the dismantling and cleaning. In addition, only one area can be cleaned with a spray, it must be dismantled and cleaned outside.
08.05.2020 19:48 # 10
ismailkaya
I have a 2005 model 1.4 90 hp vehicle.
