Is the temperature too much?
08.05.2020 16:41 # 1
carantinas
If I go with my friends in a normal way with my vehicle, the temperature is always a little under 100 or so it doesn't stop at 90, which is the reason for this?
08.05.2020 16:41 # 2
ByHack
the heat may be from the customer?
08.05.2020 16:41 # 3
hsnsnl
The thermostat can be tanned after 95 degrees & nbsp; it is not working .. the fan is always working in the tool, it is necessary to have a look.
08.05.2020 16:41 # 4
bjkamil
I also usually get over 90, close to 100. but there is no problem such models.
08.05.2020 16:41 # 5
hakan38
90 is on a line, I guess it's normal :)
08.05.2020 16:41 # 6
herry
If you go up to 100 and then go down to 90 again, you will have trouble :)
08.05.2020 16:41 # 7
Barut
I go up to 100s, 110s, but again 85 90 na iniyo is this normal friends, I changed the thermos two days ago but again the same please help
08.05.2020 16:41 # 8
[QUOTE = 206xs] I'm going to 100s to 110s, but again it is 85 90.Is this normal, guys, I changed the thermos two days ago, but again the same please help [/ QUOTE]
It does not come to the temperature when I stop and stop. is in heavy traffic. That's normal.
koliva 2012-04-13 06:40:30
08.05.2020 16:41 # 9
Cmoss06
The engines in the Peugeot vehicles are heated and 90-95-100 are normal values. On the long road, it is 90 and below, generally it is 100 or so in the city.
08.05.2020 16:41 # 10
davutayaz
I may have experienced a problem due to overheating. I had the same problem.
