Is the Temperature Normal?
08.05.2020 17:40 # 1
rolandgarros
I have a 2000 model 206 RG 1.6 90 hp 8v + LPG vehicle. The temperature in the city is generally over 90. Is my overheating value normal or above normal? It always sticks to my mind to ask is always fatal.
08.05.2020 17:40 # 2
allppeerr
yes, my normal friend, if you don't want it to rise that high, change the thermostat, I know that there are people who open it at 70 c
08.05.2020 17:40 # 3
rolandgarros
If we change the thermostat, would it be harmful for the fan to turn on early?
08.05.2020 17:40 # 4
error
it makes more sense to call the reason.
08.05.2020 17:40 # 5
It is normal. It is abnormal to go under 90 or reach the red area. You can install a 70 thermostat, but this does not allow the fan to open early. If 70 thermostat is installed, your fuel consumption will increase a little.
08.05.2020 17:40 # 6
rolandgarros
I found the picture on the internet, for example, it does not rise that much, but as long as it doesn't go to the bottom, there is nothing to be afraid of, right? Smile
08.05.2020 17:40 # 7
normal Wink
08.05.2020 17:40 # 8
SDYMZ
I think more than 110 degrees is not normal
08.05.2020 17:40 # 9
samet206
If it is not too hot, it will be a problem when the temperature exceeds 100, my friend is not normal, especially the picture is not normal at all.
08.05.2020 17:40 # 10
I think friends did not see the text under the picture.
08.05.2020 17:40 # 11
samet206
[QUOTE = koliva] I guess friends did not see the text below the picture.
Dear manager, if you told me, I saw, of course, I know that the picture does not belong to the friend. I'm saying. . Member
08.05.2020 17:40 # 12
[QUOTE = samet206] [QUOTE = koliva] I guess friends did not see the text below the picture. After passing, I say that it should be doubted. .
Dear samet "Smile"
I actually wrote it to SDYMZ friend. koliva 2013-06-09 18:07:06
08.05.2020 17:40 # 13
rolandgarros
I thank everyone, mine watches between 90-100. I wanted to add it when I found a picture on the internet "Smile" I cannot thank you all for your information and sensitivity. Thanks to you, the question marks in our minds disappear one by one. "Smile"
08.05.2020 17:40 # 14
ALBATROS06
slmlar I have 2001 206 xt, these vehicles are working hot. the original of the vehicle, don't be afraid. Do not play with the setting also do not disturb the vehicle in vain: =)
08.05.2020 17:40 # 15
rolandgarros
[QUOTE = ALBATROS06] slmlar 2001 & nbsp; There are 206 xt, these vehicles are working hot. the original of the vehicle, don't be afraid. Do not play with the setting also do not disrupt the vehicle in vain: =)
friendly vehicles "LOL"
08.05.2020 17:40 # 16
error
well, question 2: D
it is okay until I get up to 90, but when I accelerate a little, 90km, 100km immediately falls to the ground in the picture, so this is even in the heat of hell in my moments if the weather is winter. .
ha, if I use a little cycle, this event doesn't occur much.
errör 2013 -08-07 01:23:35
08.05.2020 17:40 # 17
ahmetemir
I became a new member but I have been following for a long time. Let me start my questions. & nbsp; & nbsp; The second question in this last photo is the same problem in me. Normally it falls to 70 on the plain. then I came to my mind to look through the booklet, I looked at the red line in the photo, it is the intermediate normal temperature values in front of that last red, I am surprised, it is the first time I have seen a car that has worked so hot, we have changed a lot of cars, but I have never seen such a hot, also I have looked at the fans and there is no problem even it is strange In the line after 90, the fan comes into play in the 1st level and the next one opens in the 2nd level.
