Is the problem a diesel pump? (Solved)
08.05.2020 17:51 # 1
pt206
Friends, I came to Izmir from Izmir last night, and since I got on the bus, I used my car for about 50-60 km. .When the engine is working carefully, it sounds like a stylish chic. Smile .I opened the hood to find out the source of the sound, when I listened that the engine top cover came from there from the diesel pump. Could the problem be related to the diesel pump or do you have any knowledge about it? pt206 2013-08-16 23:34:07
08.05.2020 17:51 # 2
oguzhan29
Brother, my old car had been in berlingo, a tooth of the belt was pulling out of the stylish stylish bits, I looked and changed it, but show you what you see, what is what
08.05.2020 17:51 # 3
pt206
On Thursday leave, my brother will take it, my brother.I had done before the oil change, it was cut after changing the oil so I could not describe the sound coming to the master :). Before the oil change, the engine was cut off. It comes from somewhere around the air filter of the top cover of the engine. It got stuck in the head and scabbed thoroughly.
08.05.2020 17:51 # 4
pt206
After 1.5 days of service, the problem is solved. Thanks ...
08.05.2020 17:51 # 5
pt206
The problem is injector leakage. It was at the beginning stage. I tried for a while until I described the sound to the men and realized it, but we finally found the middle way. Smile . The gasket and plastic of the 2nd or 3rd injector were due to time wear, so it made noise. The top of the engine was opened. All injectors were checked one by one. No problem occurred.
the service detected wear on the alternator belt and crank pulley when the engine was turned on. Since the ready engine was turned on, these parts were replaced and the process was completed, as it may pose a risk in the future.
08.05.2020 17:51 # 6
pt206
Thank you brother. At least I got rid of the obsession and led to the change of other wearing parts. Smile
08.05.2020 17:51 # 7
pt206
[QUOTE = onurazgin] exactly my brother, I hope they didn't make a high bill. [/ QUOTE]
all cost 480 pounds in the authorized service.
