Is the headlight / rain sensor installed later? UPDATED
08.05.2020 20:46 # 1
Orcun.Dmr
First of all sentence Selamün aleyküm, as I mentioned in the title, is it possible to have my 307 vehicle fitted with a rain sensor and a headlight sensor afterwards? Can I get the rain sensor / headlight sensor assembly out and get the necessary Sensors, Com2000 unit? Forum residents who do not know please give a comment. Smile
Correction; When replacing the windshield, I replaced it with a rain sensor glass.
orçun.dm is 2019-07-30 02:30:01
08.05.2020 20:46 # 2
samet2461
I'm telling my guesses, it would be close to the impossible to be able to do the original. Because it feels like you have to change including bsi, all of them are signal arms. Although it was original in my vehicle, I couldn't put it to 100% working position. The gel of the sensor is problematic, sometimes it does not work, the headlights stay on during the day. So it sounds impossible to do it in the original way. samet2461 2018-02-17 10:40:50
08.05.2020 20:46 # 3
Alicilik
There is no joke of the glass.
Important
Suitable sensor
Gel between sensor and glass
installation cable
COm2000 (unit with arms) change
coding of the sensor
08.05.2020 20:46 # 4
Orcun.Dmr
[QUOTE = samet2461] I'm telling my guesses, it would be close to impossible so you could do the original. Because it feels like you have to change including bsi, all of them are signal arms. Although it was original in my vehicle, I couldn't put it to 100% working position. The gel of the sensor is problematic, sometimes it does not work, the headlights stay on during the day. So it sounds impossible to do it in the original way. [/ QUOTE]
Hodja, I have an officer I know. Smile As the airbag coil is changing, I will replace it with the new original part, as it completely replaces with the Com2000 (Handles) and it is defective. I don't think BSI will change. Smile
08.05.2020 20:46 # 5
Orcun.Dmr
[QUOTE = Buyer] the glass has no joke.
Important
Suitable sensor
installation cable
The sensor and the installation will be taken out and the assembly will be made. I can't replace the COM2000 unit with the original new part, but I have no idea how to handle the gel. What do you call coding? Do I need to activate if my car currently has rain / headlight sensor mode? Smile
orçun.dm is 2018-02-18 02:54:40
08.05.2020 20:46 # 6
Orcun.Dmr
Current.
08.05.2020 20:46 # 7
Orcun.Dmr
I am updating the subject. Does anyone know? Smile I also learned something if it is true, the rain sensor and the headlight sensor were separate. The rain sensor is on the glass, and the headlight sensor is something like a small eye behind the screen on the chest (trip computer unit).
08.05.2020 20:46 # 8
monalos
You said the sensors are separate, but the sensors are in the same place on the 2side glass because when I hold my hand to the glass, the headlights are on,
With original parts that can be made
08.05.2020 20:46 # 9
Orcun.Dmr
[QUOTE = monalos] You said the sensors are separate, but the sensors are in the same place on 2side glass because when I hold my hand to the glass, the headlights are on,
With original parts that can be made [/ QUOTE]
I said it is true, but at the beginning of the sentence I said if it is true. Let's see if we can start work after one month. Smile
08.05.2020 20:46 # 10
Orcun.Dmr
I bought friends rain and headlight sensor, installation and darkened rearview mirror from 307 to 70 tly, but I am sure that it will happen. Can anyone say the idea? I have not brought the parts to the electrician friend yet. Does anyone know of any activation after the tactics of all the parts? If I do, I would definitely like to write here to the point and have 307 empty boxes. LOL orçun.dm is 2020-02-17 14:13:30
08.05.2020 20:46 # 11
maximusti
[QUOTE = Orçun.Dmr] Friends I took the rain-headlight sensor, its installation and the darkened rearview mirror from 307 to 150 tly, but I am sure that it will happen. Can anyone say the idea? I have not brought the parts to the electrician friend yet. Does anyone know of any activation after the tactics of all the parts? If I do, I would definitely like to write here to the point and have 307 empty boxes. LOL [/ QUOTE]
After the assembly process is completed, it must be coded on the BSI with software (ie activation).
08.05.2020 20:46 # 12
Orcun.Dmr
[QUOTE = maximusti] [QUOTE = Orçun.Dmr] I bought friends rain and headlight sensor, installation and darkened rearview mirror. Can anyone say the idea? I have not brought the parts to the electrician friend yet. Does anyone know of any activation after the tactics of all the parts? If I do, I would definitely like to write here to the point and have 307 empty boxes. LOL [/ QUOTE]
After coding and activating, when I press the headlight sensor activation button at the top of the signal lever, there will be a spelling stating that the headlight sensor is active on the screen? Or when I put the wiper arm to the auto position, I will give a sound. Is this coding what you call difficult or can an electrician who understands from the computer do?
08.05.2020 20:46 # 13
ismailkaya
there is no problem that cannot be solved. I will investigate and see what problems will arise.
08.05.2020 20:46 # 14
Orcun.Dmr
[QUOTE = ismailkaya] There is no problem that cannot be solved. If you put it in the head, you will, but first you have to take care of the parts and cable and socket of these equipped vehicles. let me have a look and see what problems I will encounter [/ QUOTE]
I like to fill an empty car. For example, before that, my car 4 glass automatic and mirrors were not electric, I put it on the head pull-out installation and window jacks, motors, mirrors, etc. With a figure of 800 tll, both 4 glasses were automatic and the mirrors became electricity. I bought all the installation sensor or something, the assembly is left. I do not understand the part you need to take care of the parts and cables and sockets of vehicles equipped only. Smile
08.05.2020 20:46 # 15
Orcun.Dmr
I'm updating the subject. I made the assembly of the dimming rearview mirror and the sensors, the cover was very nice to see when I put on the covers, I connected the rearview mirror myself and it was self-declining when it hit the light from behind. I cut the plumbing up to his brain, but I forgot where the cables were connected. As a missing part, only the system from the brain to the steering wheel with com2000 remained. Could I take the handle with a damaged winding sensor and transfer the winding on my vehicle?
08.05.2020 20:46 # 16
GokhaN
[QUOTE = Orçun.Dmr] I'm updating the subject. I made the assembly of the dimming rearview mirror and the sensors, the cover was very nice to see when I put on the covers, I connected the rearview mirror myself and it was self-declining when it hit the light from behind. I cut the plumbing up to his brain, but I forgot where the cables were connected. As a missing part, only the system from the brain to the steering wheel with com2000 remained. Could I take the handle with a damaged winding sensor and transfer the winding on my vehicle? [/ QUOTE]
you can do it too, as you do them too Smile
08.05.2020 20:46 # 17
Orcun.Dmr
[QUOTE = gökhan]
I do it, sir, I have electricity as a teacher, but I think how to activate it, I ask for help from our forum residents who use computers. Smile
08.05.2020 20:46 # 18
Orcun.Dmr
At the end of Eveeett I assembled all the parts, everything is ok, I put all of the sensors, arms and all but I couldn't find a place to activate the sensor in the huge industry and therefore I am thinking to replace the B02 brain with K03 on my vehicle with the J03 used in XT cases. I don't want to get coding or something because all the sensors in the XT cases are features, and only the brain changes and immobilizer coding will be done for the car to work, but I have a question mark in mind. My car's climate control panel is manual, XT cases are digital. If I plug the J03 coded brain into my vehicle, will my manual air conditioning panel work? I hope I could tell.
Note: I tried to attach the J03 bsi brain to my vehicle and I couldn't check if the sensors were working or not, because the car was not working, the air conditioner panel was working.
orçun.dm is 2019-02-06 03:04:24
08.05.2020 20:46 # 19
Halal, orch's hand and health. Just finding a master to do coding can be a problem. Some of them may be daunting. I think it will be necessary to do operations related to possible coding in j03.
08.05.2020 20:46 # 20
Orcun.Dmr
[QUOTE = sonerkyl] Whether halal or health to the arm of the orch. Finding a master who will do the coding works may be a problem. I think it will be necessary to do operations related to possible coding in j03. [/ QUOTE]
Thank you, let's say end of perseverance LOL For J03, I am only afraid that immo coding will be done, I found the master who will make it, but if my air conditioner does not work. Smile
Page : / 2
