Is the engine temperature normal? 90-110
08.05.2020 20:13 # 1
radman206
I use Pegugeot 206 1.4 hdi. I noticed something today. While driving on the highway, I saw that the engine temperature indicator is between 90/110 while using it with 90-110 km / h with 2000-3000 revolutions. Do you think this is normal?
08.05.2020 20:13 # 2
ggitaristt
Normal but at the upper limits of normal .. It is not normal for the diesel car to be so hot during normal use, but ..
I said normal, huh ..
08.05.2020 20:13 # 3
radman206
Is it normal for it to return to 90 degrees with only less feet of gas without any intervention?
08.05.2020 20:13 # 4
bazuka
There is no normal problem, but the same problem happened in my car, the master changed the air filter, it was fixed. I do not know what relevance I do not know. Just a lot of masters said nothing, but it changed when he changed the air filter.
08.05.2020 20:13 # 5
Normally it should not exceed the line above 90. Generally, the second stage fan should come on and fall down. Check the air filter. The thermostat and temperature sensor may then be problematic.
08.05.2020 20:13 # 6
Baran35
It is useful to show that the vehicle may not be normal, especially if we calculate that the vehicle does not stop and stop on the highway. Because in the city, he can take his head with a moment of forgetfulness and go away. Although it is not a very abnormal situation, I would recommend you to show it to a master, perhaps, as the friends say, if the problem is solved with a tiny air filter replacement, you will be comfortable. I wish days without accident.
08.05.2020 20:13 # 7
KILIC
If you haven't climbed a ramp or something, I think it's not normal.
08.05.2020 20:13 # 8
Oktkor
I can't read the numbers.
08.05.2020 20:13 # 9
dejawu1978
ABSOLUTELY NOT NORMAL .. Must have opened 2 levels at that level and reduces it below 90 of course. Is this increase instant or general room but I think it is not normal anyway ...
08.05.2020 20:13 # 10
vpro
It comes to those degrees when I take the 206 ramp with lpg or in tight traffic. But it watches around 95 in open traffic.
08.05.2020 20:13 # 11
talip206
In city traffic is normal, but on the long road, it is definitely not normal . Especially in these weather is not normal at all.
08.05.2020 20:13 # 12
radman206
I had the opportunity to check it out today.
The radiator was out of order. Changed.If there is improvement, I write.
08.05.2020 20:13 # 13
radman206
After the radiator changed, this time the engine never started to heat up. I travel 20 km and it is difficult to 70. Fuel consumption also increased, up to 5 cents per km. I think the thermostat is also faulty. I'll have him look at it at the first opportunity ..
08.05.2020 20:13 # 14
KILIC
The thermostat may be hungry in my opinion
08.05.2020 20:13 # 15
radman206
You say something like it is stuck?
08.05.2020 20:13 # 16
talip206
Are you saying something like [QUOTE = radman206] is stuck? [/ QUOTE]
If the thermostat is faulty, it remains open. While it normally needs to open at 89 degrees, it stays open or opens earlier. So even if the engine is cold, the water circulates. Thus, the vehicle cannot reach the ideal temperature (90 degrees) and burns very much. talip206 2017-03-28 21:19:14
08.05.2020 20:13 # 17
KILIC
Just as the suitor says, the motor cannot be heated because it is constantly circulating.
