Is the cycle normal
08.05.2020 19:27 # 1
maestro
Friends 1.6 petrol lpg 307 Is the following cycle normal at idle?
08.05.2020 19:27 # 2
tolgaakk
Yes, as it should be.
08.05.2020 19:27 # 3
tsufrankwoli
My normal teacher
08.05.2020 19:27 # 4
xmen
the cycle is normal but not indicative of heat .. :)
08.05.2020 19:27 # 5
maestro
He stayed idle for about half an hour.
08.05.2020 19:27 # 6
maestro
Actually, I watched a lot of 307 videos on youtube. https://m.youtube.com/watch?v=ftfdpog5psw maestro 2015-09-23 15:37:38
08.05.2020 19:27 # 7
xmen
What is the problem with idling, if you say it, you will be helped better ..
08.05.2020 19:27 # 8
maestro
There is a voice in the car, the masters said cups, I changed it, did not fix it, I changed the oil pump because the oil pressure was insufficient, I changed the oil pump again.
08.05.2020 19:27 # 9
xmen
If it is as seen in the picture, there is no problem in idling. If the car is going to go out or the indicator is moving while idling, it means there is a problem.
08.05.2020 19:27 # 10
yasin26
At idling, the speed of water circulation is low, however, there may be an increase in speed, but whether the vehicle's circulation pump and the radiator is clean should be checked. What is the brand of the radiator has changed?
08.05.2020 19:27 # 11
maestro
The radiator has not changed in the new circulation. I think it is clean when it comes to cleanliness.
08.05.2020 19:27 # 12
Efe-Pojo
both indicators came to me in norml. The temperature in the pejo is not always stable over 90 for some reason. It's good, but it doesn't stop. :)
