Is the clutch wire broken?
08.05.2020 21:29 # 1
AhmetSehzade
Hello, I parked my vehicle 2 3 days later I got on the clutch at the bottom pulled up with my hand, it comes up, but it stays on the bottom again, what could be the reason for this, guys?
How can I check if the wire is broken, how can I check it?
Or for what other reasons?
Can I change it if it is broken?
Would you appreciate if you could help?
08.05.2020 21:29 # 2
There is a clutch fork, my teacher may have broken through the fiber wire at his end. you can see it in the engine section. You can find the necessary information at https://partsouq.com/ .
08.05.2020 21:29 # 3
EmSul
if the wire or port is not broken, you may have scattered the print
08.05.2020 21:29 # 4
If there is a problem in printing, you will either make a sound or scrape and burn it. I think it looks like a wire-related situation.
08.05.2020 21:29 # 5
EmSul
Before I came to my head in the mondeo, there was no indication that the clutch was wasted and was left at the bottom.
08.05.2020 21:29 # 6
ukayl
Change the wire and it will be a little difficult to change it yourself.
08.05.2020 21:29 # 7
x571
When the wire is broken, the clutch becomes like a stone. You Basamaz. Nothing happens in Bassan. If you are printing and getting stuck, there is a problem with the wire.
