Is the clutch over?
08.05.2020 15:13 # 1
ask307
hi friends;
friends car tremendously vibrates at the start of the clutch is very hard car 97000 km increased in fuel I think it is time to change
08.05.2020 15:13 # 2
06KFA52
Do you think that the gap until you reach the clutch point when you press the clutch is excessive?
08.05.2020 15:13 # 3
mdincer34
my car 307 2004 97.000 de clutch change is 15.000 km at most but as you say it is tremendously tremendous on departure I think it has changed the owner before me.
08.05.2020 15:13 # 4
Serhun
To understand that the clutch lining is finished, when you want to shift the car to 5 gears and engage the hand brake and start off, the engine stops, the clutch does not miss, if it does not stop, it is missing.
Generally the symptom of the clutch lining finished is hardening and the above clutch.
The vibrating clutch pedal is also a sign of ending, but if it has just changed, the sub-industry, if there is a problem in the pressure, and only if the pad has changed, if the pad has crashed (it was crashed in the past), it may also cause vibration due to the balance problem in the pad, or balance in the press, bending, cracking, breaking, etc. In wire systems, parts that make a gap on the movement mechanism also cause vibration. In addition, if your vehicle has a sound that resembles such a sound, such as when the front gear is broken, your gearbox or engine ear is defective and as a result of this, tremor may occur during the departure.
08.05.2020 15:13 # 5
mdincer34
hmm detailed answer. my first suspicion in the vehicle was the engine ears. I made the front teams look at the master. I did it, I did not look at the ear, not from the ear. We did what you said. Let me know your piece, I don't know what the piece on it changed the owner before me.
08.05.2020 15:13 # 6
ask307
it stops in my vehicle but the clutch is too hard, too titrior and the car fell out of traction. noticed when the clutch changes, right in the car
08.05.2020 15:13 # 7
desert197
my friends, it's time to clutch because especially when I change the gears on the slopes, when I hit the gas, the hand of the rpm jumps up with the engine noise but there is no acceleration.
08.05.2020 15:13 # 8
Serhun
If the clutch does not miss, it is likely that there is a problem with the gearbox chock or engine chocks.
Recently, I changed the gearbox chock, while the vehicle was getting up, it was shaking a lot, I felt that something was playing from the bottom, and the car was shaking more while turning the steering wheel to one side. It was not easy to change the gear. Tremors also occur. But it is not very clear that the part broke down without taking it out. If your vehicle is 4-5 years old, there are problems with this type of rubber parts, easy to come
08.05.2020 15:13 # 9
mdincer34
If you have it made, it costs you incredibly trembling, the vehicle also attracts my attention, while taking off on the straight road, give the normal gas a little, set the clutch. trembling.
08.05.2020 15:13 # 10
Serhun
I bought my vehicle Clio 3 for 25 TL. There should be two people with such problems and should test the vehicle like that. You are trying to move the vehicle as if you are taking off, a person is watching the movements of the engine from anywhere he can see from above, then the parts that make up the gap are checked. Good luck with
08.05.2020 15:13 # 11
307P
How long does a clutch last?
08.05.2020 15:13 # 12
Serhun
The Services, which are very proportional to the driver and with the condition of use, seem to change an average of 80 000 km.
08.05.2020 15:13 # 13
[QUOTE = 307P] How long does a clutch last? [/ QUOTE]
Hello there.
This is very relative, depending on the vehicle model and user. In peugeout models, 80-90 thousand km of printing demands the pad. of course for this first time! If the set you are going to use is original, then you will make over 60 thousand very comfortable. of course it depends on your usage.
respects
08.05.2020 15:13 # 14
He notifies that the vehicle's clutch pressure pad is finished.
See how to get it done soon
08.05.2020 15:13 # 15
307P
Thanks guys for the answers, I have more then Sırıtma
08.05.2020 15:13 # 16
teknikerrr
There was a similar problem in my car. It was shaking. A few days before I was on the long road, the rubbing sound started in the city and I changed the thrust pad set.
But it was said that this shudder issue could be changed from the flywheel as well. Fortunately I saved it with pressure pad. There is no problem at the moment.
08.05.2020 15:13 # 17
azdek
How much does this print lining do for 307?
08.05.2020 15:13 # 18
mdincer34
I asked 307 1.4 hdi for a special service price 600 650. Here is the gearbox oil for everything including the flywheel lathe but I do not know where I am uncertain where I thought I would get all the parts from the outside but I am still waiting for the master's advice :)
08.05.2020 15:13 # 19
azdek
[QUOTE = mdincer34] I asked for a special service for 307 1.4 hdi, it costs 600 to 650. I do not know where to add gearbox oil and turning the flywheel, but I do not know where I am going to get all the parts from the outside, but I am still waiting for the advice of the master:) [/ QUOTE]
oooo brother what did they do if you burned it to you say it is great if you inform us about how you do it somehow :)))
08.05.2020 15:13 # 20
mdincer34
I got a price from the service, a little familiar, 550 said, let me see if I have to, because even if I picked up the pieces, it makes 300 350 between 350 and 350. If I stay, I will write in the form, let friends benefit already.
Page : / 2
