Is the ceiling of 307 easy to ceiling?
08.05.2020 18:45 # 1
kuantum
Panoramic glass curtain was broken. I have to remove the ceiling to examine it. I want to do this myself to minimize expenses. My skills are good. Can I disassemble it myself?
The problem I mentioned is this: http://forum.peugeotturkey.com/forum_posts.asp?TID=36418&PID=518754񾩢
08.05.2020 18:45 # 2
albayman
Hello, my friend, it was not very detailed because I wrote on the subject you opened on the phone.
if you trust manual skill and have the right tool kit, you can remove the ceiling trim and curtain mechanism. but there are points you need to pay attention.
first of all, when the curtain opens and closes, there are stop points at the end. Just like opening the windows, the last and foremost automatic, the roof curtain also stops automatically. but when we remove the battery, we need to calibrate the windows. When the motor of the roof curtain is removed from the electricity, it does not need to be calibrated because it has an electronic lap counter on it. Even if you don't have to dismantle the engine, don't forget the direction of this tour counter if you have to disassemble it, don't mix it. Do not forget this tour issue after repairing the curtain last and installing everything locally.
the curtain mechanism goes down completely, all on a single mechanism. Our moving curtain is 3 parts. the motor moves to the frontmost part with thin ropes from the back of the mechanism. The frontmost piece transmits motion to the rear pieces. If you can download the mechanism, you can see it.
A lot of trinkets will be removed to remove the ceiling trim, sun visor, handles, lamps, rear seat belts, plastics, etc. you will also unplug the sockets of each lamp. the ceiling covering comes down when these parts are removed. you should take it out from the rear tailgate and put it in a suitable place without getting dirty. then you will need to unscrew lots of curtain mechanism. Also, the socket of the engine will be removed. The mechanism comes when all the screws are removed. It is difficult to intervene in the parts without disassembling the mechanism because they are all facing upwards, namely the roof glass.
When removing parts and screws, if you work regularly, collect them separately, and take notes on pencil paper, you will not forget, if you forget, you will try to get longer and try and remove them. As the details are high, you may not be able to get out of the job. so I suggest you talk to a cautious caregiver and negotiate before you start. but it's not something like 500TL.
Maybe you can handle it alone when you disassemble the parts, but it is hard when you are wearing them so you will need another person you can trust in dexterity and patience. Good luck with...
ADDING: YOU CAN TAKE THE PHOTOGRAPHY OF THE PARTS THAT YOU CAN MIX AND PLACE ON THE TOP.
WARNING: WITH DIRTY HANDS, IT MUST BE CAREFUL TO NOT TOUCH THE CEILING FABRIC.
colonel financing 2014-10-06 22:58:21
08.05.2020 18:45 # 3
emre.koc01
My teacher, how beautiful have you told me that in my problem, the parts that ensure that the sleds overlap are broken and how can we handle it? :(
