Is the 307Sw 1.6 Hdi Pack? or 307Sw 2.0 Hdi 2.0? |
| 08.05.2020 14:06 | # 1 |
Friends are on the eve of buying a car, station wagon is not very popular, we will buy a station wagon, While browsing the web, except for the 1.6 hdi packs, the 307 sw 2.0 Hdi Esplanade caught my eye, On 307 sw vehicles, 1.6 or 2.0 are more common? whichever one we take, we'll dispose of it more easily? And most importantly, does the 2.0 model burn more than 1.6? the model with the 1.6 engine also has 110 horsepower, the model with the 2.0 engine has 100 horsepower, which is faster and more aggressive? 2.0 Hdi Esplanade sells a friend, leather seat, heated seat, I do not know that the 307s have leather seats, the top model of these vehicles? I asked a lot of questions, but you know, I'm pretty confused and we still haven't been able to buy a car. Respects
| 08.05.2020 14:06 | # 2 |
Onur |
I heard 2.0 goes more than 2.0 1.6 bits more than bidet 2.0 can be 100hp but the torque values are different I do not know clearly but the torque of 2.0 is higher
| 08.05.2020 14:06 | # 3 |
https://intvd.gib.gov.tr/internetvd/index.jsp I looked at the Motor Vehicle Tax Calculation section, when it is a 2003 model 2000 engine and it is a 7 year old vehicle, the annual amount is 788.00 TL, When it is the 2006 model and has 1600 engines, the annual tax is 471.00 TL, The cylinder volume made the difference, too, so 1600 engine started to seem more logical in this case
| 08.05.2020 14:06 | # 4 |
| 08.05.2020 14:06 | # 5 |
A vehicle with a similar appearance and clean appearance can be purchased. the price of this vehicle is extremely high, not more than 22-23. I just wanted to show it as an example. I definitely do NOT recommend automatic transmission. I http://www.sahibinden.com/40_000_km_de_2006_model_premium_sw_full_triptonik_vites-58wqqaxqq19505673wqqpxqqdisplayite? |
| 08.05.2020 14:06 | # 6 |
hello, we found a vehicle 307 sw 2005 model diesel 1.6 90 horsepower vehicle at 87 thousand, we took it to dynomoss auto test service and got it tested, all equipment was healthy, only left front fender changed, left front door, left rear door and left rear fender painted The engine gave 95 horsepower in the test, undercarriage, under the vehicle, brakes etc. It turned out smoothly, the brothers in the test said that the vehicle was clean and could be taken with peace of mind, we gave it to the deposit, and we will get it tomorrow, I did not see the 90 horsepower 2005 model, the vehicles on the internet always say 110 horsepower, why is it 90 horsepower? We make 5000 km of roads per year, 90 - 110 horsepower difference does not cause a problem, right? good evening & regards
| 08.05.2020 14:06 | # 7 |
| 08.05.2020 14:06 | # 8 |
individual |
best wishes As the old case, the 2.0lt hdi engine in 307 is 90 hp and it is old technology. The 1.6 hdi has both 90 and 110 hp options. I don't know at what speed they give their max torques, but their values in nm are as follows 2.0 hdi 90 hp - 205 nm torque 1.6 hdi 90 hp - 215 nm torque 1.6 hdi 110 hp - 240 nm torque leather armchairs are standard in some of the 307s. it does not matter much between 90 and 110 in normal use, it makes a little difference in more rapid use. good luck by the way
| 08.05.2020 14:06 | # 9 |
Thanks I was always seeing 110 horsepower in the ads, I was surprised today when I saw the 90 horsepower, I wonder if 90 horsepower is not kept? Though we have the idea of using a clean 5 years after the accident is not a problem, we do not buy it for sale. the values in the test are as follows, Adjusted power: 95.0 BHP / 69.9kW Engine Power: 90.1 BHP / 66.3KW Wheel Power: 60.3 BHP / 44.3kW Lost Power: 29.8 BHP / 21.9kW Max Power: 4830 rpm / 139,5Km / h Torque: Mmorm 171.0 Nm Max Torque: 3320 rpm /95.9 km / h Max in measurement. Speed: 4840 rpm / 139.7 km / h Individual, you say 1.6 hdi produces 90 hp - 215 nm torque, our torque is 171.0 Nm out, this indicates that I have a problem? Or are you writing my factory data? so theoretical? Respects |
| 08.05.2020 14:06 | # 10 |
individual |
greetings If you bought the vehicle in the announcement first, I do not think that car is 90 hp. 90 hp hdi's were not in the old case. 1.4 hp 70 hp, 1.6 hp 110 hp and 2.0 hp 90 hp in the old case in the new chassis, 1.6 hp 90 hp and 1.6 hp 110 hp subject to these models are coming to Turkey 307 s. I have always known the old rim sw packs with 17 wheels and 110 hp. I have been using peugeot for 13 years and I have been using 307 for the last 2.5 years. so I have some interest in the models. so I have never seen 90 hp on the sw pack model in the old case. your vehicle may have a low power or the service may have measured incorrectly. On the sites such as com from the owner, the horsepower or the equipment of the vehicle cannot be checked and referenced. they are often wrong writers. now I looked at the values you gave, there is an abnormality in the values engine power is 90 hp and wheel power is 60 hp. You should not experience such a loss of power that your front-wheel drive vehicle. Also, at what times were these hp values read? this statement is also very interesting Max Power: 4830 rpm / 139,5Km / h A diesel vehicle cannot give its max power at such a high speed. It gives the max power that I know at 4000 rpm. After that, there is a low power. It also gives the max torque between 1750-2000 revolutions, where it mentioned 3320 revolutions. I think you don't find this data correct. weird values involved Show your vehicle to the nearest peugeot service and confirm that it is 110 hp
| 08.05.2020 14:06 | # 11 |
I'm confused now, I also looked at the license of the vehicle was writing 90 horsepower there, I don't think there are any errors in the values, so at least I'm sure the vehicle is 90 hp? Shouldn't I get 90 hp? at least, if we turn around the damage, call it a card and let it go? 2006 model new chassis with a vehicle is playing 3 thousand TL in the meantime, what should we do? because that vehicle is 1.6 hdi premium
| 08.05.2020 14:06 | # 12 |
individual |
If it says 90 hp in the license, I will say that the vehicle can be 2.0 lt, but you say 1.6. it is interesting that there was 1.6 lt 90 hp in the old case If it is put into the vehicle, 90 hp is not given. 90 hp is not kept, 110 hp is not kept. but this vehicle is 2005 old case and 90 hp The difference is 3000 and the new 2006 model can be bought for 110 hp. at least it has dual-zone automatic air conditioning, esp, asr, cds, etc. equipment. The decision is yours, I don't want to mislead you.
| 08.05.2020 14:06 | # 13 |
What was written on the license in the weight of the vehicle 1444 kg? According to this size, 90 hp is what? (my head is freaked out) |
| 08.05.2020 14:06 | # 14 |
individual |
Now I have the catalog of 2 separate 307s. I write from there looking at it. 1. The catalog is without makeup for the old case. Published 06/2005 1.6 hdi 90 hp is not available in this catalog. The 2nd catalog is for the new case, that is, with make-up 1.6 hdi 90 hp 1231 kg 1.6 hdi 110 hp 1250 kg Of course, these are for 5 doors. So catalog 5 So how many kilograms are there between hb and sw? let's see old case for 1.6 gasoline hb 1193/1229 sw 1269/1305 so it seems that there is a 76 kilo difference. If we add this to the value of the new hb model, then it reaches 1307 kg. long story short is very abest in the value of the license Don't look at my fault, I always confuse you :)
| 08.05.2020 14:06 | # 15 |
Onur |
[QUOTE = Greywolf] this is the tool; [/ QUOTE] in the ad says 110 hp
| 08.05.2020 14:06 | # 16 |
:) thanks for the informations anyway :) most likely we will buy this vehicle, we showed the vehicle yesterday, when I took over the vehicle, the vehicle's power was so feel-sensible, the steering was smooth, the gears were passing normally, I don't think we will have a problem, let's see :) Respects
| 08.05.2020 14:06 | # 17 |
Onur |
If there is no problem in the test, it is not a problem. |
| 08.05.2020 14:06 | # 18 |
individual |
[QUOTE = horby37] [QUOTE = Greywolf] this is the tool; [/ QUOTE] in the ad says 110 hp [/ QUOTE] He writes that there is esp in the advertisement GreywolfA good luck again :)
| 08.05.2020 14:06 | # 19 |
[QUOTE = horby37] [QUOTE = Greywolf] this is the tool; [/ QUOTE] in the ad says 110 hp [/ QUOTE] Hello, If the announcement says 110 hp, the vehicle is not 90 hp but 90 hp, as I wrote above, it is 90 hp in the license, If we look at the ad, it is said to have an alarm and cruise control but there are no features in the vehicle. Respects
| 08.05.2020 14:06 | # 20 |
The brothers who made the test said that you can take the car with peace of mind, the test costed 50 TL. (the men are printing money, there was reno megane before us, then they looked at us, an opel astra appeared behind us, came after him in 20 minutes)
