Is that a whistling sound? Turbo want overhaul?
01.08.2022 12:27 # 1
antipollution
Friends, I took the sound in the video and published it, please check it
01.08.2022 23:59 # 2
talip206
Sir, it sounds like a turbo, but if you take it from the engine part, not the exhaust, it will be clearer.
To see if he wants a revision, the turbocharger will give a clear answer at once, not the engine mechanic.
If there is no gap in the shaft, it is not a problem.
If it only does it in the cold, your engine oil may be of poor quality or flashing
06.08.2022 12:45 # 3
antipollution
sir, I took out the turbo air hose and pulled the sound again guys. I checked the shaft by hand, there is not the slightest play in the shaft. That way the sound doesn't come from the front. But going to the back there is very little whistling through the exhaust. I passed all this and noticed in the video that there are oil drops in the turbo. I wonder if it is printing oil or is this what we call oil mist.
https://www.youtube.com/watch?v=f-oq8ip7hpI&t=1s
