Is Temperature Indication Normal To You?
08.05.2020 18:37 # 1
Foxfire
Yes Guys, as you can see in the picture, do you think this is normal?
2000 model 206 automatic gear 1.4 petrol + lpg
Radiator and heating radiator just changed
It is connected to Planet 2000, and the water temperature is at idle, the fan opening degree is normal.
When I got up, I stopped and looked, the fan is running, I am not going in the last gas.
I would say that the temperature indicator may be broken, but when it is connected to the computer, when it shows and the computer degrees are the same.
what do you think could be the problem?
08.05.2020 18:37 # 2
suppor
In mine, I always stop at 60, I asked 90 to come in a lot of hot air, the bikac master, normal pejoes came from outer space, did these cars come fixed in my car?
08.05.2020 18:37 # 3
outlaw
THERE ARE NO PROBLEMS, AS PEUGEOTS ARE HOT-WORKING ENGINES THAT ...
08.05.2020 18:37 # 4
ahmed206
Agalar my car does not exceed 100 degrees, yours does not exceed 110 I think it is not very good to work too hot, I think if you have the opportunity, replace the customer with thermostad.
It is not normal to stop at 60, the indicator may be broken. If it shows 60 at 90 degrees, it can be 120 degrees when it shows 90. I think you can have it checked. If only one possibility, but an important possibility, combined with negligence, what I am saying may come back with things such as God forbid burnt gasket and bed wrap.
08.05.2020 18:37 # 5
GokhaN
stop, if you stay on the stand, it may go up a little bit more and the weather is not a hot problem anymore.
In my car, the 2013 model 208 does not have very low values between 90 and 100 on its display. After the engine warms up, the normal 90 travels around 85, sometimes in rare cold and cool weather.
08.05.2020 18:37 # 6
Ali1905
The first stage fan is opening in 97, think so
08.05.2020 18:37 # 7
outlaw
I have double fans and I made one buttoned from the inside when the weather is very hot or when the temperature rises like this, I open the second fan from the inside ...
08.05.2020 18:37 # 8
Advantan
Mine is always standing at 85 I do not see a stir .d
08.05.2020 18:37 # 9
Foxfire
Let's change them tomorrow, let's see if it rises like this, you shouldn't continue driving.
08.05.2020 18:37 # 10
Serkan
Normally it works steadily at 90 degrees, it is okay if it goes for a short period of time in extremely congested traffic and long-term slopes, but it is not normal to work at that temperature continuously.
08.05.2020 18:37 # 11
tnt0648
I sold my 2000 model 206 xs 1.6 8V car from this trouble, no solution, unfortunately, be careful in the summer.
08.05.2020 18:37 # 12
Foxfire
Today I left the house, I went 4-5 km, the air conditioner was open, I stopped in the light of our red. the indicator was normal suddenly came to an end passed red passed stop was flashing, I waited, I turned off the air conditioner, then fell down, continued, I took it to the master, I told him to look at the facility.
I still haven't gotten a result
08.05.2020 18:37 # 13
madblueblacksea
[QUOTE = Foxfire] I left the house today, went for 4-5 km, the air conditioner was on, I stopped in the light of our crisis. the indicator was normal suddenly came to an end passed red passed stop was flashing, I waited, I turned off the air conditioner, then fell down, continued, I took it to the master, I told him to look at the facility.
the same image becomes when the temperature disconnects the cable of the sensor. The overheating indicator is coming to an end, giving a STOP warning. Look at the socket of the sender first, I got my socket
08.05.2020 18:37 # 14
muku
If you say this temperature is normal, my 206 is abnormal then :) I know the 92 turns on the fan as much as mine, I went up to the highlands in summer and never exceeded 92 on steep slopes.
08.05.2020 18:37 # 15
Foxfire
the green one has changed, for now there is no problem, try for a few days, if it happens again, we will change it to the other two, said master let's see now
08.05.2020 18:37 # 16
serkomser
I think there is no need to panic that hasn't turned red, my 307 was also reaching 110u. I had no trouble.
08.05.2020 18:37 # 17
Ali1905
Hodja 1.4 gasoline all hurts the fan in the first level 97 I think there is a malfunction in the sensor with blue plug that sends the temperature information to your car's display
08.05.2020 18:37 # 18
Foxfire
Today, the master tried to control everything one by one from the morning until the evening, everything was normal, it was opening at the normal value in the thermostat, but for some reason, I would use it without the thermostat until winter.
08.05.2020 18:37 # 19
samet206
When the fan turns on at 85 and the fan turns on when it exceeds 95, the temperature should not exceed 85 at 206. At least, when he pushes me so, he sees 90. The stone changes to the situation. It will be beneficial for you.
08.05.2020 18:37 # 20
Foxfire
Well, the master works between 90-100. Anyway, anyway, the gearbox has been overhauled. I was going to go on vacation.
Page : / 2
