Is Peugeot 307 Still Buy?
08.05.2020 21:20 # 1
coamtasis
Greetings to all,
My name is Oğulcan, I got a new driver's license and I want to buy a car, but I have no information about cars. My budget is 33 thousand TL and I like the Peugeot 307 as a result of researches. I read negative comments for the 1.4 model, most of those who did negative comments said 1.6 forehead. That's why I turned to the 1.6s. Then, when I read the 1.6 comments, they said that I should buy a 2006 model. There is only diesel in 2006 models, if I want LPG, I need to go down to 2005 or 2004 model. The car is low, I want to ride with pleasure, I do not expect performance, luxury, comfort. Which of these can I get, what choice should I choose?
Thank you from now.
08.05.2020 21:20 # 2
soncan first welcome to us. After 2006, it would be better to go to make-up safes, but if you find it a bit difficult to find those prices, the crops will come across and this may not take you out of the industry. It will be upset. The 1.4 diesel remains cumbersome due to the weight of the vehicle, but you should have another problem. this expectation varies from person to person. The reason why I recommend the 2006 make-up safes is that many chronic troubles are eliminated, so if you are well-groomed on this vehicle, it will not upset you. By the way, there are 1.6 petrol-lpg versions, brother.
08.05.2020 21:20 # 3
coamtasis
[QUOTE = sonerkyl] soncan first welcome to us. After 2006, it would be better to go to make-up safes, but if you find it a bit difficult to find those prices, the crops will come across and this may not take you out of the industry. It will be upset. The 1.4 diesel remains cumbersome due to the weight of the vehicle, but you should have another problem. this expectation varies from person to person. The reason why I recommend the 2006 make-up safes is that many chronic troubles are eliminated, so if you are well-groomed on this vehicle, it will not upset you. By the way, there are 1.6 petrol-lpg versions, brother. [/ QUOTE]
Thank you very much for the comments. I think I have 1.6 LPG but I couldn't find the prices I was looking for :) I found SW 2006 model 1.6 diesel 110 hp, is there any chronic problem, unlike hb?
08.05.2020 21:20 # 4
Make-up case is taken. If the diesel engines of these cases are well-maintained, brother, this engine has been used in vehicles such as ford-volvo for years. Except for the case length, a lot of hb difference is almost all the same. I have a friend has been using it since 2012. satisfied
08.05.2020 21:20 # 5
coamtasis
[QUOTE = sonerkyl] make-up case is taken. If the diesel engines of these cases are well-maintained, brother, this engine has been used in vehicles such as ford-volvo for years. Except for the case length, a lot of hb difference is almost all the same. I have a friend has been using it since 2012. satisfied [/ QUOTE]
Hodja, we put the car in expertise, the sound of a turbo whistle and oil leakage in a few places
What do you think it should do? He also gave the error p1351.
