Is Peugeot 306 spark plug wet brain error?
08.05.2020 21:22 # 1
uluturk44
Hello, I bought the 97 model 306, after a few days, the car started to stop working. The Peugeot special service said that spark plugs were running, whatever they did, the car did not work. They can do something like butterfly or run it, but it doesn't work normally. Has anyone experienced such a similar experience
08.05.2020 21:22 # 2
First of all, welcome to us. The removed spark plugs were wet. Is there any situation such as water loss in the vehicle, wet spark plugs or faulty coil can cause this. they probably squeezed a flammable substance like a lining spray from the butterfly probably. I think the car has LPG. Coil and spark plugs that I call to make the lpg system passive, have the pump and injectors checked.
08.05.2020 21:22 # 3
uluturk44
Thanks, as you said, they worked with the lining spray, there is water reduction. the coil cables changed everything, they canceled the lpg, but it wasn't the brainman right now
08.05.2020 21:22 # 4
if there is more water leakage from the cylinder head gasket, I don't think there is a problem in the brain. Of course, by making a computation test before, you can be absolutely certain.
08.05.2020 21:22 # 5
uluturk44
let me talk, I write the result here
08.05.2020 21:22 # 6
uluturk44
The vehicle worked, there was a problem in the brain, there is also a problem in the electrical installation, it is working now. And we have a few other problems, now they have also changed the gas pump engine when they changed it, they will return it to the place they took, sometimes it was not electric. Also, the speed of km does not work, but it may be the speedometer. One of the masters said that there is a sensor in the gearbox, he said it is necessary to change it, now he will change.
08.05.2020 21:22 # 7
get well soon with that, hodja. Exactly there is a km speed sensor, it is broken
