Is my car burning too much?
08.05.2020 21:02 # 1
lilokan
the warehouse was completely emptied My vehicle traveled 62 km in the city with 30 liras of gas? I bought lgp 3.80. Do you think it is overflowing?
What am I supposed to do lgp setting?
08.05.2020 21:02 # 2
RP393
I travel 220 km in the city with 25 lt gas.
1.6 206 - 2000 model 90 HP.
Sounds like a lot to me, but there is an open filter and OEM final muffler I guess it's mine.
08.05.2020 21:02 # 3
There is a lot of consumption, Hodja. their last maintenance etc. When was your vehicle built? coil spark plug etc. my recent time has changed.
08.05.2020 21:02 # 4
lilokan
My teacher has been in the vehicle for 1 month. Unfortunately I do not know about them
08.05.2020 21:02 # 5
lilokan
My teacher, how are you going 220 km for 25 lira? It's impossible
08.05.2020 21:02 # 6
then instruct the teacher to have a maintenance. oil - filters - spark plugs - etc. then have a nice lpg setting.
08.05.2020 21:02 # 7
RP393
[QUOTE = lilokan] teacher how do you go 220 km to 25 lira? This is impossible [/ QUOTE]
25 l teacher, around 80-82 TL. The tank is 25 liters and I fill it completely and always follow the km.
08.05.2020 21:02 # 8
reKor
excessively consuming vehicle teacher
If you make annual maintenance and lpg maintenance and settings, it will definitely make a difference.
08.05.2020 21:02 # 9
bilo131
yeah pretty much. I have 1.6 2000 md, 90 hp, I have 32 liters of storage, it is filling in 25 liters, going 290 km in the city.
08.05.2020 21:02 # 10
lilokan
My friends entered the gas setting, my vehicle. Everything comes out normally. But show the spark plugs, said the master. I showed the spark plugs elsewhere, the master was surprised how it sparked a we took one of the spark plugs and went to the part and compared them with the original. Spark plugs in my original car. And he talked about a value, not in my mind, according to the original, which is very high in value. We replaced it with the original in 4 spark plugs. I hope it has improved fuel Liloan 2018-10-05 23:10:58
08.05.2020 21:02 # 11
lilokan
measurement fuel yesterday after friends spark plugs changed. It burned 43 lira on 165 km. He burned 26 cents. I bought from LPG 3.27. Still too much fuel?
08.05.2020 21:02 # 12
fine brother no problem no lpg liter prices are high.
08.05.2020 21:02 # 13
lilokan
Thank you, teacher, thank you for your interest.
08.05.2020 21:02 # 14
hdoguc
Hello..
my car is 2007 model peugeot 206 fever 1,4i 75 hp now it is 100,000 km and it's been 2 months
10,000 maintenance has arrived and I will have it done this week.
I have the same problem, I have completed the Lpg tank (35 LT) and the gas tank and reset the KM.
After traveling 150 KM, the Lpg lamp burned red and I went to the fuel station again. 60 TL (17 LT) Lpg and 10 LT (68 TL) decreased gasoline.
I did not understand how the red light burns when my lpg tank is 40 liters and 20 liters.
my average gasoline and LPG consumption amounted to 130 TL, it seemed too much to me 150 TL to 150 KM road
Can you help with this issue?
08.05.2020 21:02 # 15
[QUOTE = hdoguc]
Hello..
First of all, welcome to us. Have a good vehicle. I wish you to use it without any trouble and trouble. There is a lot of excessive consumption in the vehicle. I had sold the same vehicle last month, I sold 308 passes. The full tank of gasoline was about 550-650 km but it had 32 liter tank inside the city. It would take 26-27 lt max. he would go 250-300 km in the city. It's not normal for your vehicle to burn this much. Do not get stuck in the lpg light, it will never show the true value. shows the approximate. If you constantly drive the vehicle, the fuel consumption will be high, but not so much. Have maintenance done, do not forget to replace the spark plugs and have a good gas adjustment. I have a lpg in my Şan 308 vehicle and I get 50 TL gasoline per month. Note: Your vehicle can be fitted with a cruise control teacher, probably I had the same model and equipment. 2007 1.4i fever
[TUBE] dme0jzjbkhw [/ TUBE]
sonerkyl 2018-10-09 14:07:14
08.05.2020 21:02 # 16
hdoguc
this week I will have the maintenance of the vehicle. I will handle both 10,000 maintenance and LPG maintenance together, but after maintenance
With the 40 LT tank and 35 LT LPG, I need to make an average of at least km in the city.
my daily use is going to work 12 KM in the morning, returning in the evening, this fuel consumption is so crazy ..
Factory data says 8.5 LT 100 KM If LPG burns 20% more, let's say 11 LT
I think it should be normal to drive an average of 300-350 KM with 35 LT LPG with this vehicle. How was this consumption in your vehicle (206)?
08.05.2020 21:02 # 17
hdoguc
Also, since the vehicle is LPG, would you recommend a total of 9000 5/40 engine structures?
I ordered 10/40 for the falcon peugeot. They sent me 5/40 in a box. Would it be a problem?
08.05.2020 21:02 # 18
hdoguc
Hello again.
I made maintenance of my vehicle's 10,000 Km.
engine oil - air, oil, pollen, gasoline filters, spark plugs, brake pad, front set (tie rod end, left arm) 4 tires (petlas PT525) 4 valves replaced with original parts (kept a lot of money)
LPG was also maintained
2 LPG filters and LPG tank Sensor changed. Setting is done ..
My car is like a newborn right now.
I filled the LPG tank fully and received 35 LT net gas at full filling
I have made 100 KM road right now and it still shows full.
Once the LPG tank is completely empty I will share how many kilometers I have traveled here.
Something alone caught my attention.
When I was filling LPG, I paid attention to the new indicator on the tank.
I saw that the tank received 20 LT of gas when the indicator became full.
that is, the indicator on the tank shows full at 20-25 lt.
It may still be showing full because the remaining 10-15 lt is added on it.
