Is my 407 burning fat ???
08.05.2020 16:07 # 1
mert_alis
& Nbsp; & nbsp; Hi 407 comfort 72,000 hdi I have a car, I have my car fully serviced every 10,000 km, but this month I delayed 1,000 km and last week I was on the long road oil level & nbsp; My car gave the warning, I went to a gas station without looking further and looked at the bar and & nbsp; When I looked at it, I saw that the oil level was in the last line on the stick and immediately & nbsp; I added 10-40 1 liter of oil, then when I asked my mechanic, he told me this was normal, do you think this is normal? Or is my car burning oil?
08.05.2020 16:07 # 2
Engin Tepe
I did not use the vehicle (407) for a long time, but in general, the oil is burnt after 7 8 thousand times in diesel vehicles, exactly 10 thousand of it has been filled at the end of the time. I saw this on vehicles I personally used.
I thought that it should not be enough to give it. We had added 1 liter immediately. & nbsp;
If there is something incomprehensible for the first time, maintain 10 thousand and there is a problem if it does the same for the second ten thousand. I do not doubt the vehicle by being affected by the first event.
08.05.2020 16:07 # 3
mert_alis
[QUOTE = Engin Tepe] I did not use the vehicle (407) for a long time, but in general, the oil is burnt after 7 8 thousand years in diesel vehicles. b> I can reduce, but I think it should not be enough to warn. It was a reverse situation, but it was reduced, we immediately added 1 liter. I do not doubt the vehicle by being affected by the first event.
& nbsp; Thank you Engin bey
08.05.2020 16:07 # 4
In the last problem, what the service tells me is (I don't know how accurate) every 1000 km of oil decreases almost half a liter in diesel and this is normal. I'm not sure as I said, but the burning of oil is absolutely true :)
08.05.2020 16:07 # 5
My father's vehicle is 307 1.4 HDi. 1 gram of oil does not reduce.
Moreover, we put a very thin oil like Castrol EDGE 0-30 sometime. Nevertheless, it did not decrease ..
I think it is not normal even to decrease half a liter at 1000km.
08.05.2020 16:07 # 6
metin
[QUOTE = mustafa_uslu] In the last problem, the service tells me (but I don't know how accurate) every 1000 km of oil will decrease by almost half a liter in diesel and this is normal. I'm not sure as I said, but the burning of the oil is absolutely true:) [/ QUOTE]
& nbsp;
how many liters of oil does this vehicle take
& nbsp;
< DIV> If it burns half a liter every 1000 km, when it comes to 10.000 maintenance, it will burn 5 liters of oil, so how much oil does this vehicle burn 5 liters?
08.05.2020 16:07 # 7
I would like to give the same answer, but because of the previous problem, my head was cluttered, I didn't clue it too much, it may be wrong in quantity, but I think the person who said it had reduced it at that time.
08.05.2020 16:07 # 8
metin
[QUOTE = mustafa_uslu] I would like to give the same answer, but because of the problem of the past, my head was disoriented, I did not get too clueless, it may be wrong in quantity, but I think it made the decline normal, then the staff that said it. [/ QUOTE]
& nbsp;
< DIV> Let me be clear, this sentence of the normal sentence never believed me. I have no experience of using a diesel vehicle, but my logic says & nbsp; a well-maintained vehicle will not do this & nbsp; & nbsp;.
08.05.2020 16:07 # 9
mert_alis
Well, it did not feel like this to me in fact, this event did not seem normal, we had 1.4h at 120,000 & nbsp; There are & nbsp; we bought the vehicle zero. & nbsp; all maintenance of this is done in the authorized service & nbsp; We have never had such a problem with this vehicle, Peugeot 407 I think they are buying 4.5 liters of oil.
08.05.2020 16:07 # 10
Mustafa Uslu and Engin Brothers;
Friends Sorry, But I Can't Join What You Say ...
For Diesel in My Vehicle I Changed My Last Oil At 12 .OOO km ... So Late Even I was counting ...
I did not lose oil until a bit,
I am currently changing the oil change of my vehicle 1OOO Km, I need to change,
I am constantly checking .... Always at the same level, there was no question of a millimeter reduction. .
I think it is beneficial in a detailed investigation of 4O7's not so normal oil reduction ...
AlbaYDemircaN 2011-09-14 15:25:09
08.05.2020 16:07 # 11
berk2309
Well, oil does not shrink, nekdar is diesel, but we have a boxer. put oil in diesel already 15 seconds run oil oil black gasoline like & nbsp; is not also service & nbsp; It makes oil change at 20.000 km for boxers & nbsp;
08.05.2020 16:07 # 12
berk2309
Bidet see under the vehicle or something.
08.05.2020 16:07 # 13
There may be a leak. Especially it can throw the oil out of the crankcase gasket.
08.05.2020 16:07 # 14
mert_alis
& nbsp; Thanks everyone, I will keep the car under review for now, and I will check the oil level and gold at intervals
