Is it uncertain?
08.05.2020 19:18 # 1
Beyaz206
Hi guys, I bought a 2006 model 206 HDI shortly ago. While the first few guns were smooth, suddenly, when I locked the doors from the control, the problem of getting locked and reopened and then the Aırbag lamp came on and the speed indicator remained installed at 10 km. Many people in the forum complained of similar elegance. but everyone's solution is different. Some said EGR, some said the Bey, some said speed-prompter. I will ask for suggestions from friends who have experienced similar problems and completed the process positively.
08.05.2020 19:18 # 2
Cyrus35
Professor S. aleyküm is only related to the door lock switches only when the doors are closed and opened immediately.
There was a location in the forum about this malfunction. Your first job is to diagnose a faulty door lock. You will try this by removing the sockets in the door one by one.
Press the door lock button on the remote control behind each socket. If the same problem persists, reconnect the socket you disassembled, switch to the socket on another door and follow the same procedure. Once you find the faulty lock, squeeze a lot of pad spray into the lock, then wd-40 a little, clean and lubricate and try again. If you say I do not understand the socket work, you can apply this method to all doors.
When you detect the faulty lock, you can sometimes adjust the lock striker, that is, when the door is closed, by moving the piece that is like the small ring in its counter and inserted with a 3 tors allen, slightly up and down, or you can temporarily get rid of this situation if the plastic on it is broken. If it bothers you very much, you can get an alarm and solve the problem permanently with a separate remote :)
As for the meter counter work, ask;
Can be a speed sensor,
It can be in Km engine of meter on the instrument panel,
The worst might be from the brain.
I heard that on some issues you could cause this in your Akünun, I could not bring certainty to it.
IF YOU NEED TO SORT YOUR COUNTER PROBLEM FROM CHEAP TO EXPENSIVE SOLUTION.
* If you have a familiar mechanic with them, you can take the tool on the fiber and check the speed km sensor socket from the bottom and clean it. You test again if the problem persists, if it continues,
* Replace the km engine on your dashboard. There is a fee of 60 TL.
* If the problem persists in following up the transactions. Have it connected to a diagnostic device and see if it is brain related. Get well, the electronics of the Pejos are sensitive.
08.05.2020 19:18 # 3
Beyaz206
Thank you my friend
We don't have a master since we bought a new vehicle. That's why I think to take it to the authorized service
But first I'll try what you say about water doors
Thank you for the information
08.05.2020 19:18 # 4
Cyrus35
I ask you to solve the door by yourself, the service can offer between 200 and 250 per lock.
08.05.2020 19:18 # 5
Beyaz206
If the speedometer fails at the same time with the Airbag lamp, it makes me feel like there is a problem in the brain :(
08.05.2020 19:18 # 6
Cyrus35
Is your horn working? Or do you occasionally work?
08.05.2020 19:18 # 7
Cyrus35
Airbag light can be caused by ridiculous reasons, except for one real fault. (Airbag Wrap) is a cable that is processed with this horn. located inside the steering wheel inside the com2000 unit. When there is a disconnection in this or when there is a play in the airbag sockets etc. . .
08.05.2020 19:18 # 8
Beyaz206
There is no problem in the horn, but there may be a lack of contact with the cables under the seat because there is a light gap in the seat, as if the screw is loose. tomorrow, let me go all over and go to the service according to the situation. give 100TL price to the service fault detection :)
08.05.2020 19:18 # 9
samet206
The panels are failing quickly, it seems that there is a problem with the electronic parts, not all of them overlapped in this way in the 206's.
samet206 2015-06-06 18:18:52
08.05.2020 19:18 # 10
vpro
Is the battery intact and master?
08.05.2020 19:18 # 11
madblueblacksea
I can suggest that you make a trial by turning the electronic system off and then on again. I thought it might be useful because it resets the position of the indicator dials.
- Turn everything off (ceiling lamp, tape, headlight etc.)
Open the hood, leave the driver's window open and close all the doors
-Remove the pole, wait 5-10 minutes and put it back on again
Wait for 5 minutes and lay out the window you left open and light up the car's parks
Your hands will hit hard zero and a voice will sound like Gonk
If a question arises that it is not enough to remove the pole head and put it on immediately, the answer is no. The reason is that the capacitors in the system contain current. After removing it, you can think of waiting as the time it takes for the system to stabilize.
madblueblackse to 2015-06-05 19:30:12
08.05.2020 19:18 # 12
Beyaz206
Like a joke. Burning right headlight this evening does not light. I think there is a serious electrical problem in the vehicle
08.05.2020 19:18 # 13
Beyaz206
My friend's speedometer is not stuck actually. It freezes to normal once in a while
08.05.2020 19:18 # 14
sezar206
these are simple problems. You will cut the battery to the master. Do not make sure that the problem of your problem is big probability or close to the end of the akun without checking these two first. If the trouble is one of them, then the big challenge is the charge dynamo. When you do this, all of these problems will go away. When the door came to the door, he did it for me sometime, he was squeezing and hurting, then he was making it to the pressure.
08.05.2020 19:18 # 15
samet206
In my opinion, look at the battery, then look at the BSI. If there is a battery problem in the vehicle, if it can be ridiculous, I think it was stopping on the road when the car had a battery problem. Apart from that, the display is normal, the panels are malfunctioning in 206. But the simple things are not the things to be stuck on.
08.05.2020 19:18 # 16
madblueblacksea
[QUOTE = Beyaz206] My friend speedometer is not stuck actually. It's getting back to normal once in a while [/ QUOTE]
So.?
08.05.2020 19:18 # 17
Beyaz206
Friends, today I went to private service. We solved the failure of the speedometer and the airbag lamp being turned on synchronously with the change of the speed sensor or part called the sensor. If the door is locked with the remote control and it hurts again, it is solved by canceling one of its cables instead of detecting and replacing the door motor. Now the door is locked without any problems. The downside is that when I open the door, the ceiling lamp does not light automatically. Not really important
Thank you for your kind attention and help.
