Is it suitable for meat 20 value 206
08.05.2020 15:21 # 1
Waiting for your comments, respected members
08.05.2020 15:21 # 2
rim width is important. The rim can change in the offset by width. What is the width of the wheel rim?
If you look at the original wheels used in the 206's, they are usually offset around 25-30. On the other hand, if it is 20, ten sides that will stand out from the light ...
08.05.2020 15:21 # 3
195 50 15 my master
08.05.2020 15:21 # 4
[QUOTE = facemelowe] 195 50 15 my master [/ QUOTE]
My beautiful brother I did not ask you the tire size :)))
I said what is the width of the rim :))
or if you ask for the rim you want to buy, we will try to figure out its width but it will probably be 6 or 6.5 "in general.
the cecol 2011-04-28 13:03:45
08.05.2020 15:21 # 5
dukenukem82
It is the meat value that fits 206 vehicles between 16-25 and the rim should not be more than 7 offset so that it does not rub
08.05.2020 15:21 # 6
[QUOTE = dukenukem82] It is the meat value that fits 206 vehicles between 16-25 and the rim should not be more than 7 offset to avoid rubbing [/ QUOTE]
no, my brother is 16 vs notzzzzzzzzzzzzzz because the rim comes out very well ... brother you heat corba yaa :))
There was a minute in the list and I'll add it in my find
the cecol 2011-04-28 13:08:35
08.05.2020 15:21 # 7
http://forum.peugeotturkey.com/forum_posts.asp?tıd=14125&title=a-dan-z-ye-peugeot-jant on
In the list I have provided, review the 206, 207, 307, 308 rims. they all fit together. offsets around 25-35. It is not suitable for 206 to 25. because it rims out of the fenders ...
but on average, 6 ", 6.5" wide 15 "wheels for 25-30 offset is ideal for 206.
the cecol 2011-04-28 13:17:05
08.05.2020 15:21 # 8
dukenukem82
tmm I wrote without looking at the rim size and I did not give it more than 6.5 rim thickness there, I just wrote so that it would not be like the hawks :))
08.05.2020 15:21 # 9
dukenukem82
By the way, I was going to buy a rim, I dropped the phone.
08.05.2020 15:21 # 10
[QUOTE = dukenukem82] um, I wrote it without looking at the rim size and I did not give it more than 6.5 rim thickness there, just to make it not like the hawks:)) [/ QUOTE]
I understand that when you say it, others may not understand :))
In fact, the rim width you call "7 offset" there :)
ET goes offset at offset ...
there is a lot wrong in the market ... offset rim expression Sırıtma
If it is meant to mean worn out rim, it should be called low offset or wider rim. Depending on the condition, pit medicine should be chosen on the rim.
08.05.2020 15:21 # 11
dukenukem82
yes, I wrote that to explain this, otherwise et = offset I learned this from this site already :)
08.05.2020 15:21 # 12
http://forum.peugeotturkey.com/forum_posts.asp?tıd=14388&pn=2&title=206-jant-alacam-yardm
We made the full explanation in the light and it will illuminate you
08.05.2020 15:21 # 13
Today, I put on the rim, my brothers came out a little bit out front. But it was time for 10 of 10 people :)
08.05.2020 15:21 # 14
I wish the best. Did you get the rim?
15 "oz du aren't you?
08.05.2020 15:21 # 15
abi rim + tire cost me 400 lira. balancing and tipping 20 lira ..
I bought a friend from Istanbul Sariyer
facemelow to 2011-04-29 00:22:36
