Is it possible to change the tachometer?
08.05.2020 17:36 # 1
Aziz
please pay attention to the cycle, it has been doing this for the last 3-5 days, I have been reaching 207 km at 5500rpm, I guess since I changed the oil, I don't know if it has anything to do. :) there is also a change in acceleration. (fuel total) previously my car was going into the breaker even at 212, now when I reach 207 km speed, I am very surprised at the speed 5500 :) 1000 times more is left to me but road and traffic does not allow unfortunately :) but it may be in such a problem after this dervir or passed 210 can I then pull out gear or pads?
08.05.2020 17:36 # 2
Gokhan Cetin
What was the vehicle like fine
08.05.2020 17:36 # 3
Aziz
As I wrote in my signature, 206 GTI
08.05.2020 17:36 # 4
It can be done at 220. Be careful.
[TUBE] 8gSNfUs8g-M [/ TUBE]
08.05.2020 17:36 # 5
Aziz
[QUOTE = hLL 206]
The thing I want you to pay attention to is to compare our speed dials with the speed dial.
< p>
speeds are the same on the screen shots but the cycles are different
see:
my tachometer
see:
other 206 gti tachometer
[QUOTE = 307bursa] the car started to open, so I think there is no other problem:) [/ QUOTE]
Brother is good Did you say something bad? & nbsp; "LOL"
08.05.2020 17:36 # 6
Alicilik
Did you compare it with GPS
08.05.2020 17:36 # 7
Aziz
[QUOTE = Buyer] Did you compare with the brother of GPS
good idea, one-to-one information could not be pranha you have exceeded 90 speed limit after coming 110 in my old company warning he gives? When you were going with a fixed 120, it was showing 112 or so. How can we solve this event, if I catch my rada, at this speed :) Where can I test this performance since joking?
08.05.2020 17:36 # 8
Aziz
[QUOTE = 307bursa] well I said something yawn! You see 210 u, but don't think this is my brother, let me relate the incident by saying that they are the servant structure again :))))
oh my brother is relieved :)
the former owner did not give his right, but he did not wear out the vehicle. & nbsp;
1 - BlackGTI nikli (ibrahim) My friend said to me, take off the pole, wait for 15 minutes, then put the pole back on, turn on the ignition, wait until the lights go off, turn the ignition off, start the car, exit the brain lpg settings, reset it, this is the first solution
I did this two weeks ago, but I did not speed it up, and without doing that work I went to the breakers at different speeds, as I said in the previous. Like 212 - 215-27 km. now I have reached 207 km at 5500 rpm. & nbsp;
2 - can it be related to exhaust? the possibility of the first muffler and exhaust clogged interrupts the vehicle? & nbsp; because exhaust was not installed in my hgs narration, I wasn't pressing it at my box office passes and going into the breaker after 210?
3 - 2 times oil in 1 month I made the change and used the engine cleaning product (würth) in the second one. This is the final solution.
4 - All? & nbsp;
I asked very mixed questions but I want to answer all of them if possible?
08.05.2020 17:36 # 9
Alicilik
[QUOTE = Aziz] [QUOTE = Buyer] Did you compare it with gps
good idea, one-to-one information can't be pranha after my 110 came in my old company Was warning that you have exceeded the 90 speed limit? When you were going with a fixed 120, it was showing 112 or so. How can we solve this event, if I catch my rada, at this speed :) Where can I test this performance since joking?
Brother rot you have to go to the balancers. speed and speed on the dial were the same. If there was a deviation beam at certain speeds of the wheel, it was measuring it.
08.05.2020 17:36 # 10
Aziz
[QUOTE = Buyer] [QUOTE = Aziz] [QUOTE = Buyer] Did you compare it with GPS
good idea, one-on-one and no pranha Was warning that you exceeded 90 speed limit after 110 in my old company? When you were going with a fixed 120, it was showing 112 or so. How can we solve this event, if I catch my rada, at this speed :) Where can I test this performance since joking?
Brother rot you have to go to the balancers. speed and speed on the dial were the same. If the deviation at certain speeds of the wheel fln was measured.
okay called my speed adjustment? Can I visit the door by door, find out if there is a device or not? I'm going like that.
08.05.2020 17:36 # 11
Bugra
[QUOTE = Aziz] [QUOTE = hLL 206]
< p>
see:
my tachometer
see:
Brother is good did you say something bad? & nbsp; "LOL"
< / div>
Aziz, when you look between your vehicle and the other vehicle, the speeds are the same, but there is only 500rpm between you and the other vehicle. so this is not a huge difference, like. But as Ali said, try it with a GPS or get a familiar vehicle with 90 fixes, it shows 90m. Take a look. The speed may be a little wrong, showing like 5-10 km. dayno came to my mind, is it there? if there is an error ....
08.05.2020 17:36 # 12
SDYMZ
Well, if the tire diameter is different, is such a situation not observed?
08.05.2020 17:36 # 13
allppeerr
Hodja, your car is very different with the oil temperature of the car in your video.
08.05.2020 17:36 # 14
ByHack
Speed is a disaster :(
08.05.2020 17:36 # 15
Aziz
[QUOTE = bugrature]
Aziz, in these pictures, when you look between your car and the other car, the speeds are the same, but there is only 500rpm between you and the other car. so this is not a huge difference, like. But as Ali said, try it with a GPS or get a familiar vehicle with 90 fixes, it shows 90m. Take a look. The speed may be a little wrong, showing like 5-10 km. dayno came to my mind, is it there? if there is a mistake .... / div>
08.05.2020 17:36 # 16
Aziz
[QUOTE = allppeerr] Hodja, I think your oil is very different with the oil temperature of the car in the video. I will show you the reason for the hgs record. & nbsp; salt and ice izmit exit 140 km (due to not shearing and bends) for a long time, 200 km long, at this distance I finished a quarter tank. I am trying not to tighten it too much since I bought it or it has been 4 or 2 months.
08.05.2020 17:36 # 17
tigerland
oil temperature capped & nbsp;
08.05.2020 17:36 # 18
emre_akdag
[QUOTE = Aziz] [QUOTE = Receiving] [QUOTE = Aziz] [QUOTE = Receiving] Did you compare it with gps
good idea, one There was a pranha who could not find any information after my 110 110 in my old company was giving the warning that you exceeded 90 speed limit? When you were going with a fixed 120, it was showing 112 or so. How can we solve this event, if I catch my rada, at this speed :) Where can I test this performance since joking?
okay called my speed adjustment? Can I visit the door by door, find out if there is a device or not? I'm like that.
[/ QUOTE] dyno-test Aziz. Let's look at a query like this. I think he has to take a dyno-test.
08.05.2020 17:36 # 19
ZP105
dude, your speedometer shows more 206 gti makes 210 at 6 thousand cycles
makes 200 at 6 thousand cycles if it is short
08.05.2020 17:36 # 20
ZP105
Also, the oil change is so funny, my teacher, what the speed of the cycle with the oil change: D: D
Page : / 3
