Is it normal to open a fan at 206+ 100 degrees?
08.05.2020 19:07 # 1
ayna
Friends, I went to Erzurum last weekend. It is a city with a slope. I used the car very hard that day. Because it is in the city, I made hard departures in 1 2 gear. The temperature rises in the city. Normally there is no problem here. 100u was very light and the car turned on for the first time. I was afraid that it would be a long time, I burned the hood, opened it, stopped it, waited it, I started it 5 minutes later, I continued, I got out of the city, the car fell back to 70e. Is it normal to open a fan, friends? What should I do in such a situation? Was it right for me to stop?
08.05.2020 19:07 # 2
talip206
I think there is nothing normal to be afraid of. That is the duty of the mortal. the important thing is that it doesn't get too close to the limit. If there is no situation such as water leakage or vehicle dehydration, the radio is not pierced, it will not stop, it will be idle while it is running. talip206 2015-02-27 19:21:27
08.05.2020 19:07 # 3
ayna
So it doesn't get too close to the red ground? Wouldn't it be a problem if I continued to use it that way? How many should I stop the car if it exceeds?
08.05.2020 19:07 # 4
talip206
There is the path to the red line. The vehicle will warn you if you already need to stop. The stop sign lights up on the screen. As far as I know, the fan turns itself on around 110.
08.05.2020 19:07 # 5
ayna
Hmm, I understood that it was over 100 but very few meant 110 did it.
