Is it normal to open 308 trunk lid halfway?
08.05.2020 20:02 # 1
ozgurkso
Hello friends 2012 when I lift my trunk 308 with a make-up case, it is necessary to push it again to open it halfway, it is normal.
08.05.2020 20:02 # 2
monalos
It can be from the trunk shock absorber.
08.05.2020 20:02 # 3
OguzhanKucuk61
It is normal. This is to be expected, as the trunk dampers have lost their function. I experienced the same gradually. When I first picked up the car, it applied an opening force towards the end. Over time, it got worse and I lift my boot lid completely and there is no slight support. And as such, when the dampers are completely dysfunctional, it is necessary to close them as well as the bonnet. Otherwise it closes too hard. The essence of the work needs to change. While the luggage damper set of normal 206 hbs is 40 lira, we use it when my shock saver's shock absorber set is 360 lira.
08.05.2020 20:02 # 4
ozgurkso
Thank you for your comments. Baggage door is not automatic 2012 makeup case 308 I used hb for years alone, I thought that it should not deteriorate so quickly. Do you have friends who use 308 to open up to the end, I would be glad if especially friends who use 308 comment in order not to change shock absorbers.
