Is it normal to click so much at 308 |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (2008-2013) | |
| 08.05.2020 19:27 | # 1 |
Does a C-class vehicle use this much poor quality material, even the door handles squeak, or is it mine? |
| 08.05.2020 19:27 | # 2 |
ahmet_bjk |
I use 308 too, but I haven't heard any creak and the material quality is also very good. I did not understand where the sound was coming from Doors squeak or come from rubber tires |
| 08.05.2020 19:27 | # 3 |
[QUOTE = ahmet_bjk] I am using 308 too, but I have not heard any squeak and the material quality is also very good in my opinion. I did not understand where the sound was coming from Doors squeak or come from rubber tires [/ QUOTE] I can't predict where the sound is coming from, there are so many sounds that I say, whether I say through the door, inside the seat belt, if I say the sizzle from the windshield, I can't predict where it came from. But in general, there is a lot of noise coming from plastic parts. That's why I'm selling the back 6 my car I bought before :( In addition to these, the interior door handles seem to break, do you? When it is very thin and lightly pressed, it starts to creak, |
| 08.05.2020 19:27 | # 4 |
it has nothing to do with a class c car. It means that the owner or the owners have used contempt before you. Sometimes a clip breaks, the door trim makes a lot of noise, a screw loosens in the display section on the dashboard, so it needs to be found. I am using 2007 model 207, there is no sound from anywhere
| 08.05.2020 19:27 | # 5 |
Do you have any information about the history of the vehicle ... probably the owner or owners before you used contempt ...
| 08.05.2020 19:27 | # 6 |
It may be used for contempt or related to the accident he made. Once the van had hit the car, the wheels were on the sidewalk. Even minor accidents can cause the car to flex and make noise. Usage is also very important.
| 08.05.2020 19:27 | # 7 |
the vehicle has potentially been hit, that is, it has lost its originality
| 08.05.2020 19:27 | # 8 |
Efe-Pojo |
every voice has a solution for this, the car is not sold :) I do not know what your previous car was, but the material quality of the piano is not behind other similar vehicles, it is 2 shirts superior to the renodan.
| 08.05.2020 19:27 | # 9 |
It is obvious that the vehicle was used. Even though I was careful to pass slowly, I determined that the glass of the rear trunk lid dashboard started to make sound everywhere, I corrected it, I am changing my way again, so as not to go through the belts. |
