Is it normal that the temperature is 100 at idle in 307?
08.05.2020 16:51 # 1
mmetinn1985
friends 307 1.6 16v gasoline in my car shows the temperature on the long road just under 90 degrees. But when it stops, the temperature rises at idle, and when it is over 100 degrees, the fan turns on and the temperature drops to 95. Then, when the fan turns off, the temperature rises again. even if there is not a lot of traffic in the same way when traffic stops and stands up I just caught my attention, I remember that it was always under 90 before. Friends using 307 are 100 overheating in traffic and idling. If there is a problem, where do you think? thermostat, circulation, overheating, thank you for your help now.
08.05.2020 16:51 # 2
It is perfectly normal.
We would appreciate if you can introduce yourself as per the forum rules.
http://forum.peugeotturkey.com/forum_posts.asp?TID=7516&title=new-yers-cautine-contact-not- read < / a> Reviews
08.05.2020 16:51 # 3
albayman
I have the same situation. 307sw 1.6 petrol 2005.
1998 model opel corsa would turn on a 100 degree fast fan and turn it to 95 degree slow. Interesting situation.
08.05.2020 16:51 # 4
mmetinn1985
In a few forums, they wrote that they fixed similar topics with a thermostat, and it got stuck in my head. & nbsp;
08.05.2020 16:51 # 5
[QUOTE = mmetinn1985] In some forums, they wrote that they fixed similar topics with thermostats from him. & Nbsp;
How do you fix with a thermostat? Even if you take the thermostat out and throw it away, the hot water will start to circulate in the radiator and the fan will start cooling immediately. Do not look at others believe here "Smile"
08.05.2020 16:51 # 6
mmetinn1985
:) you are the normal diode?
08.05.2020 16:51 # 7
mbuyukavci
My 307 is the same, but when I ask the master, he has two mores. The first 100 and the second one open in 170 leer. There is no problem, this is quite normal, you always meet the summer :) I mean, this is normal bro.
08.05.2020 16:51 # 8
mmetinn1985
thank you teacher
08.05.2020 16:51 # 9
[QUOTE = mbuyukavci] My 307 is the same, but when I ask the master, he has two mores. The first 100 and the second one open in 170 leer. There is no problem, this is quite normal, it always said that you will meet constantly :) so this is the normal situation. = "0" alt = "LOL" title = "LOL" /> I think you have mixed it.
It is true that it has two fans but "Smile"
08.05.2020 16:51 # 10
mmetinn1985
There is only one fan with 2 fans, and it is speeding up gradually.
08.05.2020 16:51 # 11
metin
Everything is normal, never look at the temperature is fine.
08.05.2020 16:51 # 12
toga406
Do not believe the gaskets that explode at 170 degrees due to residual pressure.
