Is it junyan? sonar?
08.05.2020 13:59 # 1
Ismail
JUNYAN ? SONAR ?
08.05.2020 13:59 # 2
Junyan
08.05.2020 13:59 # 3
Junyan
08.05.2020 13:59 # 4
iLLeGaL
I USE JUNYAN ANGEL VERY SATISFIED AND ITS QUALITY AND ITS VIEW ...
08.05.2020 13:59 # 5
Ismail
3/3 JUNYAN AHEAD ....
08.05.2020 13:59 # 6
ENGIN
I also use junyan, but where can we find the spare part of these junyan I want to ask ..
08.05.2020 13:59 # 7
They suggested me junyan. I think Junyan is better than Sonar.
junyan h1 or friends..h7 is there angel farda? 34GS767 2008-12-04 19:42:25
08.05.2020 13:59 # 8
nakrevip
As far as I know, there is 1 difference in quality. I use JUNYAN as an image, and I think it looks better than sonar. But when installing the headlights, it is beautifully with black sealant, it blows from the late edges and thoroughly, otherwise it makes steam with 70% probability and annoys this aRADA junyan h1
08.05.2020 13:59 # 9
[QUOTE = 34GS767] They suggested me junyan. I think Junyan is better than Sonar.
junyan h1 or friends..h7 is there angel farda? [/ QUOTE]
h1
If you say you want to finish my junjan, I think I will get both fk
but if you choose between the two, junjan because sonar's led bulbs do not change, you can change if led park bulbs burst in junjanda
08.05.2020 13:59 # 10
ac8088
I have a new type of white ring burning sonar and the bulbs are changing: S rings of the world are burning yellow, right?
08.05.2020 13:59 # 11
hasimayaz
It comes on the engine throughout the FK. Sati The yellow LEDs of the fk in Turkey but abroad available in burning white models as well. LEDs change is very simple and 5 yellow leds are used for illumination of each angel. There is an opening cover for repair. Since motor cables do not have a socket, they must be pulled in parallel by pulling parallel from the existing connector.
In some models of Junyans, the engine that comes out of the original headlight can be fitted to a new one. . There is no chance of motor in the sonars. There are 2 white leds for each angel in Junyan and Sonars and they are difficult to repair. 1.5 volt leds are fed by coil. For repair, the new leds must be soldered to pertinaks by removing their senses.
The transparent parts of the FKs are more fluffy, so the gap between the bonnet is very low, especially in 106 vehicles. After the Junyan and Sonars are installed, the bonnet adjustment may be required to clear the opening.
It is absolutely necessary to be insulated with silicone in all its brands during assembly. Even if there is no problem for that moment, it may cause silicone to lose its silicon feature in the future.
Our little article on headlight siliconing:
08.05.2020 13:59 # 12
[QUOTE = ac8088] I have a new type of white ring burning sonar and the bulbs are changing: S rings of the world are burning yellow, right? [/ QUOTE]
yes but your car is 206. i have 106 junjan white led is on
08.05.2020 13:59 # 13
hasimayaz
VEHICLE 106 is Junyan Angel eyes, 306 is headlight dimming, 206 or saxo mk2 is morette group, 307 or 207 is FK angel eyes ..
08.05.2020 13:59 # 14
gokhanozmen
junyan :)
08.05.2020 13:59 # 15
sinan-s
Of course, junyan .. All the products of the world are white.
08.05.2020 13:59 # 16
junyan :)
08.05.2020 13:59 # 17
deniz_206
NO SUSPICIOUS JUNYAN Thumbs% 20up
08.05.2020 13:59 # 18
taylan43
when i bought junyan before, angles burst 2 months later, but i have been using sonar for 8 months and nothing more, i am really glad, i think SONAR ...
08.05.2020 13:59 # 19
FK and Junyan
08.05.2020 13:59 # 20
I have junyan but it doesn't have any old taste either I would say morette or the standard headlight is black ground and one layer is transparent black from inside
Page : / 2
