Is fog lamp ornamental
08.05.2020 21:19 # 1
Dogukan_3002
Hi guys Smile Does anyone know where our 206's rear fog lamp is on?
08.05.2020 21:19 # 2
doganatak
It lights up on the arm where you light the headlights, but only when the dipped and high beam is on. You see the icon on it already. When it is lit, the light comes on in the display. You can burn it by turning the ring. Of course there is no change in the connection etc ...
08.05.2020 21:19 # 3
Dogukan_3002
[QUOTE = doganatak] Lights the headlights on the arm you burned, but only when the dipped beam is on. You see the icon on it already. When it is lit, the light comes on in the display. You can burn it by turning the ring. Of course there is no change in the connection etc ...
Could you watch it as of 1:45. so I couldn't function like that
[TUBE] qhgcrephxm0 [/ TUBE]
08.05.2020 21:19 # 4
doganatak
[QUOTE = Dogukan_3002] [QUOTE = doganatak] Illuminates on the arm where you light the headlights but only when the dipped beam is on. You see the icon on it already. When it is lit, the light comes on in the display. You can burn it by turning the ring. Of course there is no change in the connection etc ...
I am at work, I can't turn up and watch. You will turn the one next to the rotary knob you turn on the headlight.
08.05.2020 21:19 # 5
OguzhanKucuk61
To open the shorts is not necessary to burn. When the parks push forward the spring-return control on the right side of the same arm, the front fog is pushed again, the rear fog lights. If you see the symbol that the fog is on the display and the fog is not lit, the bulbs may be cut off. If there is no fog light, it is not ornamental.
