Is engine oil spoiled?
08.05.2020 16:48 # 1
206206
friends & nbsp; 5 years & nbsp; shell helix 10/40 diesel & nbsp; I had engine oil. & nbsp; 4 lt & nbsp; & nbsp; Cover not opened & nbsp; home & nbsp; I kept it. & nbsp; My car had been taken care of the other day. I used this oil & nbsp; I wonder if & nbsp; damage to the vehicle & nbsp; olurmu & nbsp; & nbsp; oil put on engine & nbsp; It's 1000 km & nbsp ;, master & nbsp; when you put the oil into the engine consistency & nbsp; there was no problem. color & nbsp; like & nbsp; it was normal.
08.05.2020 16:48 # 2
Normally the shelf vertebrae are 5 years. I do not think it will be a problem, but it is useful to observe the oil status from the oil cubes once in a while. & Nbsp;
08.05.2020 16:48 # 3
206206
& nbsp; If there is no oil level, & nbsp; yogunlugunu my & nbsp; i should check
08.05.2020 16:48 # 4
[QUOTE = 206206] from the oil & nbsp; If there is no oil level, & nbsp; yogunlugunu my & nbsp; I should check [/ QUOTE]
You better watch both. When you take the
Bar, the oil should be smooth and shiny. It should also be a little transparent. There should be no oil or muddy particles inside. When you crush the oil with two fingers, it should not be too thick, nor the con should be thin. Must be in the middle of the two. I hope I could explain "Smile"
08.05.2020 16:48 # 5
206206
thank you & nbsp; I understand & nbsp; :)
