Is a 307 16 rim attached to 15?
08.05.2020 14:09 # 1
ozgurkso
I would like to install 15 or 14 wheels to soften the suspension on my 307 1.6 hdi original16 rim vehicle. Will there be any problems with rubbing or any problems on the front disc calipers?
08.05.2020 14:09 # 2
berko
It should be 205 55 16 tires on 16 rims, I think it is not very comfortable to switch to 15 rims, if the tire air is 32 and 31 or 30, the vehicle will be more comfortable. I used 15 in 206 and took 14 for the winter, and nothing changed.
08.05.2020 14:09 # 3
ozgurkso
If I switch to 15 rims, the comfort will definitely increase with the size 195-65-15.
08.05.2020 14:09 # 4
berko
cheek thickness will be 195 * 65, 12.675 cm instead of 205 * 55, that is, 11.275 cm, so nothing will change. Anyway, reducing it from 35 psi to 33 is a free try.
08.05.2020 14:09 # 5
ozgurkso
If I rub the caliper on 15 rims, I heard 15 rim discs different.
08.05.2020 14:09 # 6
if you change the tires and if the rim has bobbins
08.05.2020 14:09 # 7
Onur
It happens at 15 and 14 after the wheel bolts are spaced. 14 would be too small, not good
08.05.2020 14:09 # 8
coyote26
15 rims can be used smoothly ... not at 14 but it is suitable for disc and calipers.
08.05.2020 14:09 # 9
Doktor
I think it's okay at 15, but I wouldn't recommend 14 to a car like 307
08.05.2020 14:09 # 10
H-a-d-i
If the wheel bolt spacing is suitable, a 15 "rim can be installed.
08.05.2020 14:09 # 11
Look, there is an issue that you should not forget. As much as the vehicle's tire needs to be pressed as factory data, using it from the air below will cause both the tire to be worn from the outside and the road grip as well as the braking and cornering capability. Because of that pain, I certainly do not recommend reducing the air of the tires. You may encounter a situation suddenly because of the lack of tire air. of course not show Allah. I think the only thing that can be done is 15 "rim. Of course, the subject of knocking into the brake caliper should be investigated. I guess that you can learn this by going to any authorized service. 195 or 205 65 15 can be used as a tire. the cecol 2010-04-07 14:33:39
08.05.2020 14:09 # 12
controller
[QUOTE = berko] There should be 205 55 16 tires on 16 rims, I think it is not very comfortable to switch to 15 rims, instead of making the tire air 32 or 31 or 30, the vehicle will be more comfortable. I used 15 in 206 and took 14 for the winter and nothing changed. [/ QUOTE]
My friend what happened to this issue ?? I want to go from 15 to 16, I can see if you want?
Controller 2010-04-28 00:45:39
