Is 206 temperature values normal? |
| 28.05.2021 10:17 | # 1 |
| 28.05.2021 10:22 | # 2 |
| 28.05.2021 20:06 | # 3 |
It's not a problem for a gasoline vehicle, sir. The same is happening to us. I have been using 206 for 5 years. Do not worry if the fan falls when you turn it on, does not stand on the red line and does not give a warning
| 29.05.2021 19:25 | # 4 |
Thanks for your answer, I don't get any warnings, but it makes you nervous that this pointer moves up whenever the vehicle stops.
| 31.05.2021 16:32 | # 5 |
In the forms, a friend wrote that the fan was sorry in 83 and 98. If it is in those values, there is no problem. I also see 98 at most. Vehicle in extreme traffic 1.4 HDi 206
| 31.05.2021 23:29 | # 6 |
I guess it's a general situation that doesn't cause a problem with these values in extreme traffic in my vehicle.
| 01.06.2021 13:29 | # 7 |
hello, this temperature situation is considered normal in peugeots, I asked many services, they say it is normal unless they see the red line, they say, does the temperature drop or go out while you are on the road? |
| 01.06.2021 13:31 | # 8 |
If the temperature is above 90 when you park your vehicle, wait, the fan will cool down to 90 degrees, then if you stop, it will be suitable for the engine.
| 01.06.2021 23:23 | # 9 |
As soon as the vehicle moves, it drops to 90 degrees when it goes for 1-2 minutes without traffic, and if the vehicle remains stationary, I see these values
| 01.06.2021 23:24 | # 10 |
I will try, thank you for your reply
| 02.06.2021 09:18 | # 11 |
Could there be a problem with circulation? It would be healthy to be observed by a master.
| 09.08.2021 03:30 | # 12 |
In my car, the first stage fan turns on here, is this normal?
